Group Policy Management Console
Group Policy Management Console is an administrative tool for managing Group Policy across the company. If you want to audit Group Policy, Group Policy Management Console must be installed on the computer where Netwrix Cloud Agent resides.
Follow the steps to install GPMC on Windows Server 2012 and above.
  1. Navigate to Start > Control Panel > Programs and Features > Turn Windows features on or off.
  2. In the Add Roles and Features Wizard dialog that opens, proceed to the Features tab in the left pane, and then select Group Policy Management.
  3. Click Next to proceed to confirmation page.
  4. Click Install to enable it.
Follow the steps to install GPMC on Windows 8.1 and Windows 10.
  1. Depending on your OS, download and install Remote Server Administrator Tools that include Group Policy Management Console.
  2. Navigate to Start > Control Panel > Programs and Features > Turn Windows features on or off.
  3. Navigate to Remote Server Administration Tools > Feature Administration Tools and select Group Policy Management Tools.
Protocols and Ports Required for Monitoring Active Directory, Exchange, and Group Policy
Review a full list of protocols and ports required for monitoring Active Directory, Exchange, and Group Policy.
  • Allow outbound connections from the dynamic (1024 - 65535) local port on the computer where Netwrix Cloud Agent resides.
  • Allow outbound connections to remote ports on the source and inbound connections to local ports on the target.
Tip for reading the table: For example, on the computer where Netwrix Auditor Server resides (source), allow outbound connections to remote 389 TCP port. On domain controllers in your domain (target), allow inbound connections to local 389 TCP port.
PortProtocolSourceTargetPurpose
389TCPNetwrix Cloud AgentDomain controllersLDAP Common queries
3268TCPNetwrix Cloud AgentDomain controllersLDAP Group membership GC search
3269TCPNetwrix Cloud AgentDomain controllersGlobal catalog LDAP over SSL
88TCP/UDPNetwrix Cloud AgentDomain controllersKerberos authentication
135 and dynamic range: 1024 -65535TCPNetwrix Cloud AgentDomain controllersWindows Management Instrumentation gpupdate /force
445TCPNetwrix Cloud AgentDomain controllersSMB 2.0/3.0 Authenticated communication between Netwrix Cloud Agent and domain controllers.
53UDPNetwrix Cloud AgentDomain controllersDNS Client
135 and dynamic range: 1024 -65535TCPNetwrix Cloud AgentExchange Server- Windows Management Instrumentation - Retrieve Exchange Server configuration settings* - Run gpupdate /force * gpupdate /force
5985 5986TCPNetwrix Cloud AgentExchange Server- Windows Remote Management - PowerShell connections: - 5985 - for HTTP - 5986 - for HTTPS
Enable Secondary Logon Service
Step 1 – On the computer where Netwrix Cloud Agent resides, navigate to Start > Windows Administrative Tools (Windows Server 2016 and higher) or Administrative Tools (Windows 2012) > Services.
Step 2 – In the Services dialog, locate the Secondary Logon service.
Step 3 – Right-click the service and on the General tab make sure that Startup type for this service is other than Disabled. Startup type can be either Automatic or Manual.
