Connection
The Connection node contains objects referred to as Connection Profiles. A Connection Profile houses the information Enterprise Auditor uses to connect to the target hosts during job execution.
Connection
There are two methods for authentication to a targeted host:
  • Use Local Login Credentials
  • Use a Connection Profile
Use Local Login Credentials​
This method is traditionally assigned through the Only use the Windows account that the application is run with System default option. It is generally referred to as the System Default or trusted method. When used, Enterprise Auditor authenticates to the target hosts during host inventory or job execution with the Windows account used to launch Enterprise Auditor. This can be:
  • Account which was used to log on to the Enterprise Auditor Console server and start the application
  • Account which was used to launch the Enterprise Auditor application through the run-as security context
  • Account which was used to provision a Windows scheduled task when running a job group or job via a scheduled task
Use a Connection Profile​
Use this method to define a Connection Profile that houses one or several sets of credentials to be used for authentication on the target hosts during host inventory or job execution. The credentials specified in a Connection Profile could be any of the following:
  • Local machine account
  • Active Directory account
  • Unix account
  • SQL account
  • Microsoft Entra ID (formerly, Azure Active Directory) key
  • Dropbox access token
  • Web service JWT
  • Oracle account
For the majority of auditing scenarios, domain-based accounts are preferred if not required by the nature of the auditing task. The credentials must have the permissions required by the data collector being used.
Password Storage Options​
You can store the password for the credential provided in the Enterprise Auditor application or Enterprise Auditor Vault. You can store certain types of credentials in CyberArk®.
Choosing to store passwords in either the Enterprise Auditor application or the Enterprise Auditor Vault is a global setting configured in the Settings > Application node. See the Application topic for additional information.
The Enterprise Auditor vault provides enhanced security through enhanced encryption to various credentials stored by the Enterprise Auditor application. See the Vault topic for additional information.
CyberArk integration stores supported credentials in the CyberArk Enterprise Password Vault. CyberArk Privileged Account Security Solution offers components designed to discover, secure, rotate, and control access to privileged account passwords used to access systems through the enterprise IT environment. See the CyberArk Integration topic for additional information.
Cancel and Save options
The Cancel and Save buttons are in the lower-right corner of the Connection view. These buttons become enabled when you make modifications to the Connection global setting.
Information update message box
Whenever you make changes at the global level, click Save and then OK to confirm the changes. Otherwise, click Cancel if you don't want to save the changes.
