AD_ShadowAccess Job
This job finds shadow access that leads to compromise of a domain or sensitive data. Attackers can chain vulnerabilities to escalate privileges from a non-privileged user to administrator with only a few steps. This job will generate the shortest path between every non-privileged user to a domain administrative group, total domain compromise, or access to sensitive data.
This job will analyze the following links between resources and privileges in your environment:
  • Effective Group Membership
  • Modify Group Membership
  • Reset User Password
  • Access through adminSDHolder
  • DCSync/Domain Replication privileges
  • Shared passwords between domain accounts
  • Groups that provide access to sensitive data
  • Local administrators that can dump hashes from user sessions
  • Administrative rights on SQL Servers that hold sensitive data
The AD_ShadowAccess Job has special dependencies. See the Recommended Configurations for AD Permissions Analyzer Solution topic for additional information.
Analysis Tasks for the AD_ShadowAccess Job​
Navigate to the Active Directory Permissions Analyzer > AD_ShadowAccess > Configure node and select Analysis to view the analysis tasks.
Don't modify or deselect the selected analysis tasks, with the exception of the Calculate Shadow Access analysis tasks. The analysis tasks are preconfigured for this job. The Calculate Shadow Access analysis task is the only analysis task that has customizable parameters.
  • Shadow Access Schema – Sets up the Shadow Access Tables and Views
  • Dijkstra – Creates an interim processing table in the database for use by downstream analysis and report generation
  • Path Formatting – Creates an interim processing table in the database for use by downstream analysis and report generation
  • String Split – Creates an interim processing table in the database for use by downstream analysis and report generation
  • Calculate Shadow Access – Creates the SA_ShadowAccess_Details table accessible under the job’s Results node
  • Shadow Access Paths Cleanup – Removes calculated rows that are no longer used
In addition to the tables and views created by the analysis tasks, the AD_ShadowAccess Job produces the following pre-configured reports.
Domain Shadow AccessThis report will calculate the shortest path between highly sensitive privileges and non-privileged users.NoneThis report is comprised of five elements:
  • Bar Chart – Displays summary information on targeted domain
  • Table – Provides details on targeted domain in table form
  • Table – Provides details on exploited permissions
  • Table – Provides details on vulnerabilities
  • Table – Provides details on domain users and attack paths that can be used against those domain users
Sensitive Data Shadow AccessThis report will calculate the shortest path between highly sensitive data and non-privileged users.NoneThis report is comprised of five elements:
  • Bar Chart – Displays summary information on sensitive data
  • Table – Provides details on sensitive data in table form
See the Report Functions for the AD_ShadowAccess Job topic for additional information.
Customizable Analysis Tasks for the AD_ShadowAccess Job​
The default values for customizable parameters are:
Analysis TaskCustomizable Parameter NameDefault ValueInstruction
Calculate Shadow Access@session1Set to 0 to turn off Session Analysis
@shared_password0Set to 0 to turn of Shared Password Analysis
@modify_group_membership1Set to 0 to turn off Modify Group Membership analysis
@sensitive_data1Set to 0 to ignore sensitive data attacks
@dcsync1Set to 0 to ignore dcsync rights
@sdholder1Set to 0 to ignore sdadminholder
@disabled0Set to 0 to ignore disabled users
See the Configure the Analysis Tasks for the AD_ShadowAccess Job topic for additional information.
Configure the Analysis Tasks for the AD_ShadowAccess Job​
Customizable parameters enable Enterprise Auditor users to set the values used to classify user and group objects during this job’s analysis. The parameters can be customized and are listed in a section at the bottom of the SQL Script Editor. To customize an analysis task’s parameters:
Step 1 – Navigate to the Active Directory Permissions Analyzer > AD_ShadowAccess > Configure node and select Analysis to view analysis tasks.
Configure Calculate Shadow Access task from Analysis Selection view
Step 2 – In the Analysis Selection view, select the Calculate Shadow Access analysis task, then click Analysis Configuration. The SQL Script Editor opens.
SQL Script Editor
Step 3 – In the parameters section at the bottom of the editor, find the Value column. Double-click the current value and change as desired.
  • If the variable type is a table, select the cell and click Edit Table to modify the value.
Don't change any parameters where the Value states Created during execution.
Step 4 – Click Save and Close to finalize the customization and close the SQL Script Editor window.
The customizable analysis task parameters are now configured and ready to run.
Report Functions for the AD_ShadowAccess Job​
The reports generated by the AD_ShadowAccess Job presents users with an overview of vulnerabilities and attack paths within the targeted environments.
Shadow Access reports in the job's Results node
Navigate to the Active Directory Permissions Analyzer > AD_ShadowAccess > Results node to view the AD_ShadowAccess job reports.
These reports can also be accessed through the Web Console. See the Viewing Generated Reports topic for additional information.
Exploited Permissions and Vulnerabilities on Shadow Access reports
The Domain Shadow Access and Sensitive Data Shadow Access reports provide information on the exploited permissions and vulnerabilities that can be used as attack paths for shadow access to domain and sensitive data.
  • Exploited Permissions – Displays summary information of the types of permissions that can be exploited by shadow attacks and the number of occurrences of those permissions
  • Vulnerabilities – Displays summary information of the vulnerabilities that were detected and the number of occurrences of those vulnerabilities
Report element displaying information on potential attack paths for users found in the targeted domain
The last report element displays information on potential attack paths for users found in the targeted domain. Click the green plus sign next to an attack path to open an Attack Path window that displays a step-by-step process of how an attacker can use a compromised user object to conduct a shadow attack.
Attack Path window example
The Attack Path window displays how a user object can be used in a shadow attack.
  • Example:
    • The Everyone principle has the rights to reset the password of LSA
    • LSA can modify group membership of Domain Admins
    • The Attack Path window reveals that every user in the domain is effectively a Domain Admin
The number of objects and the direction of the arrows can change depending on the attack path and related elements.
  • Example:
    • The testgroupuser10 user object is a Local Admin on the TESTS server
    • A user object that has a session on the TESTS server is a member of the Domain Admins group
    • If the testgroupuser10 user object becomes compromised, an attacker can scrape the password hash on a user object’s local session on TESTS that also is a member of Domain Admins and become a Domain Admin itself
