AWS_StaleGroups Job
The AWS_StaleGroups job highlights groups that have members that are considered stale. The definition for staleness is set by default to 60 days. This can be configured.
Parameter Configuration​
The Configuration section on a Job's overview page lets you modify any customizable parameters used by analysis tasks in the job. See the Parameter Configuration topic for instructions on how to edit parameters on a job overview page.
The AWS_StaleGroups job has the following configurable parameter:
  • Days without log in to consider an account stale
See the Customizable Analysis Tasks for the AWS_StaleGroups Job topic for additional information.
Analysis Tasks for the AWS_StaleGroups Job​
Navigate to the AWS > 3.Groups > AWS_StaleGroups > Configure node and select Analysis to view the analysis tasks.
Don't deselect the selected analysis tasks. The analysis tasks are preconfigured for this job. Only modify the analysis tasks listed in the customizable analysis tasks section.
  • Stale Group Details – Highlights the staleness of users in AWS groups. Creates the AWS_StaleGroup_Details table accessible under the job’s Results node.
  • Stale Group Summary – Summarizes statistics for stale groups. Creates the AWS_StaleGroup_Summary table accessible under the job’s Results node.
  • Stale Groups AWS Summary – Summarizes stale groups by percentile for all of AWS
Customizable Analysis Tasks for the AWS_StaleGroups Job​
The default values for parameters that can be customized are:
Analysis TaskCustomizable Parameter NameDefault ValueValue Indicates
Stale Group Details@StaleThreshold60Days without log in to consider an account stale
See the Configure the Customizable Parameters in an Analysis Task topic for instructions on how to modify parameters.
Report for the AWS_StaleGroups Job​
In addition to the tables and views created by the analysis task, the AWS_StaleGroups job produces the following preconfigured report:
ReportDescriptionDefault TagsReport Element
Stale GroupsThis report determines the staleness of group membership.NoneThis report is comprised of the following elements:
  • Stacked Bar Chart – Displays group membership
  • Table – Shows group membership
  • Table – Provides details on group membership
