AWS_StaleRoles Job
The AWS_StaleRoles job provides details on roles that are considered stale, highlighting roles that haven't been used in more than 60 days and those that have never been used. The 60 day parameter is configurable.
Parameter Configuration​
The Configuration section on a Job's overview page lets you modify any customizable parameters used by analysis tasks in the job. See the Parameter Configuration topic for instructions on how to edit parameters on a job overview page.
The AWS_StaleRoles job has the following configurable parameter:
  • Days without log in to consider an account stale
See the Customizable Analysis Tasks for the AWS_StaleRoles Job topic for additional information.
Analysis Tasks for the AWS_StaleRoles Job​
Navigate to the AWS > 4.Roles > AWS_StaleRoles > Configure node and select Analysis to view the analysis tasks.
Don't deselect the selected analysis tasks. The analysis tasks are preconfigured for this job. Only modify the analysis tasks listed in the customizable analysis tasks section.
  • Stale Role Details – Highlights the roles in AWS that are considered stale. Creates the AWS_StaleRole_Details table accessible under the job’s Results node.
  • Stale Role Summary – Summarizes stale roles by AWS Account. Creates the AWS_StaleRole_Summary table accessible under the job’s Results node.
Customizable Analysis Tasks for the AWS_StaleRoles Job​
The default values for parameters that can be customized are:
Analysis TaskCustomizable Parameter NameDefault ValueValue Indicates
Stale Role Details@StaleThreshold60Days without log in to consider an account stale.
See the Configure the Customizable Parameters in an Analysis Task topic for instructions on how to modify parameters.
Report for the AWS_StaleRoles Job​
In addition to the tables and views created by the analysis task, the AWS_StaleRoles job produces the following preconfigured report:
ReportDescriptionDefault TagsReport Element
Stale RolesThis report identifies stale roles in the AWS environment.NoneThis report is comprised of the following elements:
  • Stacked Bar Chart – Displays top stale roles by account
  • Table – Shows stales roles by account
  • Table – Provides details on stale roles
