FS_RestoreInheritance Job
The FS_RestoreInheritance job is designed to restore inheritance to previously quarantined files.
Analysis Tasks for the FS_RestoreInheritance Job​
Navigate to the FileSystem > Cleanup > 3. Quarantine > FS_RestoreInheritance > Configure node and select Analysis to view the analysis tasks.
  • Determines candidates for restored inheritance – Creates the SA_FS_RestoreInheritance_CandidatesView table accessible under the job’s Results node
Action Tasks for the FS_RestoreInheritance Job​
Navigate to the FileSystem > Cleanup > 3. Quarantine > FS_RestoreInheritance > Configure node and select Actions to view the action tasks.
Don't enable the action unless it is required. Disable the action after execution to prevent making unintended and potentially harmful changes to Active Directory.
Don't modify the action task. The action task is preconfigured for this job.
The following action tasks are deselected by default:
  • Restore Permissions – Restores permission inheritance to quarantined files where activity has occurred
