3.Broken Inheritance > FS_BrokenInheritance Job
The FS_BrokenInheritance job is designed to report on resources with Broken Inheritance from targeted file servers.
3.Broken Inheritance > FS_BrokenInheritance Job in the Jobs Tree
The FS_BrokenInheritance job is located in the 3.Broken Inheritance job group.
Parameter Configuration​
Use the Configuration section on a Job's overview page to modify any customizable parameters used by analysis tasks in the job. See the Parameter Configuration topic for instructions on how to edit parameters on a job overview page.
The FS_BrokenInheritance job has the following configurable parameter:
  • Only analyze folders with changed permissions – Set a value of 1 or 2 to select if the job analyzes only folders with modified permissions:
    • 1 – Only analyze resources with changed permissions from parent
    • 2 – Analyze all resources regardless of permission changes between parent and child
See the Analysis Tasks for the FS_BrokenInheritance Job topic for additional information.
Analysis Tasks for the FS_BrokenInheritance Job​
View the analysis tasks by navigating to the FileSystem > 3.Broken Inheritance > FS_BrokenInheritance > Configure node and select Analysis.
Most of these analysis tasks are preconfigured and shouldn't be modified and/or deselected. There are some that are deselected by default, as they are for troubleshooting purposes.
  • 1. Analyze Broken Inheritance
    • Creates an interim processing table in the database for use by downstream analysis and report generation
    • Creates the SA_FS_BrokenInheritance_UniqueTrustees table accessible under the job's Results node
    • Creates the SA_FS_BrokenInheritance_UniqueTrusteesPivot table accessible under the job's Results node
  • 2. Choose to analyze only folders with modified permissions – Creates an interim processing table in the database for use by downstream analysis and report generation
    • By default set to only analyze resources with changed permissions from parent
    • Can be modified to analyze all resources regardless of permission changes between parent and child. See the Parameter Configuration topic for additional information.
    • Alternatively, you can set this by modifying the @FILTER_TO_CHANGED_RESOURCES parameter. See the Configure the Customizable Parameters in an Analysis Task topic for additional information.
  • 3. Determine Permission Changes – Creates an interim processing table in the database for use by downstream analysis and report generation
  • 4. Analyze Trustee Differences – Creates an interim processing table in the database for use by downstream analysis and report generation
  • 5. Inheritance Types. Categorizes Permission Changes – Creates an interim processing table in the database for use by downstream analysis and report generation
  • 6. Summarize by Share – Creates an interim processing table in the database for use by downstream analysis and report generation
The following analysis tasks are deselected by default:
  • 7. Bring Table to Console - Unique trustees – Restores the SA_FS_BrokenInheritance_UniqueTrustees table to be visible under the job's Results node
  • 8. Bring Table to Console - Trustees pivot – Restores the SA_FS_BrokenInheritance_UniqueTrusteesPivot table to be visible under the job's Results node
In addition to the tables and views created by the analysis tasks, the FS_BrokenInheritance job produces the following pre-configured reports:
Broken Inheritance by Share (Broken Inheritance Details)Broken inheritance between resources can lead to incorrect access for users, either overprovisioning them, or locking them out of critical data. This report identifies the shares and folders with the most permission changes from the parent resource.NoneThis report is comprised of three elements:
  • Bar Chart – Displays top five shares by permission changes
  • Table – Provides details on folders
  • Table – Provides details on shares
Unique TrusteesThis report identifies permission changes between folders. These trustees have been either removed, added, or had their rights adjusted.NoneThis report is comprised of one element:
  • Table – Provides details on unique trustees
