FS_SecurityAssessment Job
The FS_SecurityAssessment job is designed to provide a security assessment of all relevant information from targeted file servers. It is dependent upon the following jobs:
If you run only select sub-job groups, the overview report has blank sections.
FS_SecurityAssessment Job in the Jobs Tree
The FS_SecurityAssessment job is comprised of analysis and reports which use the data collected by the 0.Collection job group and analyzed by the jobs listed previously.
Analysis Task for the FS_SecurityAssessment Job​
View the analysis tasks by navigating to the FileSystem > FS_SecurityAssessment > Configure node and select Analysis.
  • Assess Risk – Creates the SA_FS_SecurityAssessment_Details table accessible under the job’s Results node
  • Summary – Creates the SA_FS_SecurityAssessment_Summary table accessible under the job’s Results node
In addition to the tables and views created by the analysis task, the FS_SecurityAssessment job produces the following pre-configured report:
Security AssessmentThis report identifies common issues and vulnerabilities across your file systems.GDPR SOX HIPAA PCI-DSS GLBA ITAR FERPA FISMA ISO27001This report is comprised of four elements:
  • Table – Provides details of the scan Scope
  • Pie Chart – Provides details of findings by risk
  • Table – Provides details of findings by category
  • Table – Provides a summary of risk assessment details
