SQL: Criteria
The Criteria page is where criteria to be used for discovering sensitive data are configured. It is a wizard page for the Sensitive Data Collection category.
The options on the Criteria page are:
Use Global Criterion Selection – Select this option to inherit sensitive data criteria settings from the Settings > Sensitive Data node. See the Sensitive Data topic for additional information.
Use the following selected criteria – Select this option to use the table to select which sensitive data criteria to scan for
- Select All– Click Select All to enable all sensitive data criteria for scanning
- Clear All – Click Clear All to remove all selections from the table
- Select the checkboxes next to the sensitive data criteria options to enable it to be scanned for during job execution
The table contains the following types of criteria:
System Criteria – Lists pre-defined criteria
User Criteria – Lists user-defined criteria
Use the Sensitive Data Criteria Editor in the Settings > Sensitive Data to create and edit user-defined criteria. See the Sensitive Data Criteria Editor topic for additional information.
Adding unnecessary criteria can adversely impact the scanner performance and can cause the scanning job to take a long time. If performance is adversely affected, revisit the sensitive data scanning criteria and remove criteria that is not required.
