Criteria Tab
Configure the list of selected sensitive data criteria that will be used within sensitive data scan jobs using the Criteria Tab.
Sensitive Data Criteria tab
The options on the Criteria Tab are:
  • Add – Opens the Select Criteria window to add search criteria that Sensitive Data scan jobs inherit. See the Select Criteria Window topic for additional information.
  • Remove – Removes the selected criteria, so Sensitive Data scan jobs no longer inherit them
  • Launch Editor – Opens the Sensitive Data Criteria Editor. See the Sensitive Data Criteria Editor topic for additional information.
  • Search selected criteria – Filter the criteria listed in the Criteria tab
The Cancel and Save buttons are in the lower-right corner of the Sensitive Data view. These buttons become enabled when you modify the Sensitive Data global settings. Whenever you make changes at the global level, click Save and then OK to confirm the changes. Otherwise, click Cancel if you didn't intend to make changes.
Select Criteria Window​
Add Search Criteria for Sensitive Data scan jobs:
Add criteria
Step 1 – Click Add to open the Select Criteria window.
Step 2 – Select the checkbox for each criterion you want. Use the Search Criteria text field to filter the list by keyword, or expand each category to view and select individual Sensitive Data search criteria.
Step 3 – Click OK to confirm changes. The Select Criteria window closes.
Step 4 – Click Save on the Sensitive Data view to save changes.
Sensitive Data scan jobs that use global sensitive data criteria settings now inherit the selected Search Criteria.
