FS_DEFEND_SDD Job
The FS_DEFEND_SDD Job exports sensitive data matches collected by the File System Solution Sensitive Data Discovery Auditing jobs to Threat Manager. It is available through the Instant Job Library under the File System library. See the Instant Job Wizard topic for instructions to add this instant job into the Jobs tree.
For installing the job, select Local host on the Hosts page of the Instant Job Wizard. Then set the host list according to the following information.
FS_DEFEND_SDD job in the Jobs tree
Runtime Details:
  • Dependencies – The following job groups must be successfully run before running this job
    • FileSystem > 0.Collection Job Group
    • FileSystem > 7.Sensitive Data Job Group
  • Special Instructions
    • A Connection Profile must be created using the Web Services (JWT) credential account type with the specified Threat Manager App Token and assigned to this job
    • The Threat Manager host name with port, [HOST]:8080, and App Token are generated within Threat Manager:
      • Navigate to the Configuration > App Tokens page
      • Create a new app token
      • Copy the Host Name and Token
      • See the Access Analyzer Integration topic of the Netwrix Threat Manager Documentation for additional information.
  • Target Hosts – Custom Host List
    • Threat Manager target host is the Threat Manager host name with port, [HOST]:8080
    • Format – [HOST]:8080
    • Assign host list at the FS_DEFEND_SDD > Configure > Hosts (see the Hosts Node topic for additional information)
  • Scheduling – This job should be scheduled to run as desired
  • History Retention – Not supported and should be turned off
  • Multi-console Support – Not supported
The FS_DEFEND_SDD Job runs an analysis task that generates the SA_FSAA_SDD_RESULTS table, which places the data in a compatible format for Threat Manager. It then runs an action task using the Web Request Action Module to send the data to Threat Manager.
Analysis Tasks for the FS_DEFEND_SDD Job
Navigate to the Jobs > FS_DEFEND_SDD > Configure node and select Analysis to view the analysis tasks.
Default Analysis tasks for the job
  • Create FSAA DEFEND table – Creates the FSAA_SDD_RESULTS table accessible under the job’s Results node
Actions for the FS_DEFEND_SDD Job
Navigate to the Jobs > FS_DEFEND_SDD > Configure node and select Actions to view the actions.
CAUTION: This action is enabled by default.
Default Action Tasks for the Job
The default action is:
  • Integrate – Uses the Web Request Action Module to send data to Threat Manager
Custom Connection Profile for FS_DEFEND_SDD Job
The FS_DEFEND_SDD Job requires a custom Connection Profile to authenticate to Threat Manager. The credential for the Connection Profile must be created with the Web Services (JWT) account type. Remember, the Threat Manager App Token is generated within Threat Manager.
Create a Connection Profile and set the following information on the User Credentials window:
  • Select Account Type – Web Services (JWT)
  • Domain – Not a field for this type of credential, defaults to <WSJWT>
  • User name – Not a field for this type of credential
  • Password Storage: Application – Uses Access Analyzer’s configured Profile Security setting as selected at the Settings > Application node
  • Access Token – Copy and paste the Threat Manager App Token
See the Application topic for additional information.
