FS_MigrateSchema Job
The FS_Migrate_Schema Job migrates the schema in order to support the use of 64-bit ResourceID's without affecting data. It is available through the Instant Job Library under the File System library. See the Instant Job Wizard topic for instructions to add this instant job into the Jobs tree.
For installing the job, select Local host on the Hosts page of the Instant Job Wizard.
Runtime Details:
- Dependencies – None
- Target Hosts – None
- Scheduling – This job should be scheduled to run as desired
- History Retention – Not supported and should be turned off
- Multi-console Support – Not supported
- Additional Notes – None
The FS_Migrate Schema Job migrates the schema in order to support the use of 64-bit ResourceID's without affecting data.
Analysis Tasks for the FS_MigrateSchema Job
Navigate to the Jobs > FS_MigrateSchema > Configure node and select Analysis to view the analysis tasks.
- 1.Migrate Resources – Migrates the SA_FSAA_Resources table to leverage 64-bit IDs
- 2.Migrate UnixRights – Migrates the SA_FSAA_UnixRights table to leverage 64-bit IDs
- 3.Migrate Gates – Migrates the SA_Gates table to leverage 64-bit IDs
- 4.Migrate GatesProxy – Migrates the SA_FSAA_GatesProxy table to leverage 64-bit IDs
- 5.Migrate Exceptions – Migrates the SA_FSAA_Exceptions table to leverage 64-bit IDs
- 6.Migrate ProbableOwners – Migrates the SA_FSAA_ProbableOwners table to leverage 64-bit IDs
- 7.Migrate FileSizes – Migrates the SA_FSAA_FileSizes table to leverage 64-bit IDs
- 8.Migrate FileTypes – Migrates the SA_FSAA_FileTypes table to leverage 64-bit IDs
- 9.Migrate FileAges – Migrates the SA_FSAA_FileAges table to leverage 64-bit IDs
- 10.Migrate FileTags – Migrates the SA_FSAA_FileTags table to leverage 64-bit IDs
- 11.Migrate DFS Links – Migrates the SA_FSDFS_Links table to leverage 64-bit IDs
- 12.Migrate DLP Matches – Migrates the SA_FSDLP_Matches table to leverage 64-bit IDs
- 13.Migrate DLP MatchHits – Migrates the SA_FSDLP_MatchHits table to leverage 64-bit IDs
- 14.Migrate DLP MatchHits Subject Profile – Migrates the SA_FSDLP_MatchHits_SubjectProfile table to leverage 64-bit IDs
- 15.Migrate FSAC ActivityEvents – Migrates the SA_FSAC_ActivityEvents table to leverage 64-bit IDs
- 16.Migrate DailyActivity – Migrates the SA_FSAC_DailyActivity table to leverage 64-bit IDs
- 17.Migrate FSAC RenameTargets – Migrates the SA_FSAC_RenameTargets table to leverage 64-bit IDs
- 18.Migrate FSAC Exceptions – Migrates the SA_FSAC_Exceptions table to leverage 64-bit IDs
- 19.Refresh Views – Updates viewable metadata
