SystemInfo: Probable Owner
On the Probable Owner page, select options for determining the owner using weighted calculations. This page is enabled when the Probable Owner property is selected on the Results page.
Determine owner
In the Determine owner section, select from the following options:
- Determine owner from User Profile Last Modified Date
- Determine owner from User Profile Size
- Determine owner from Current User
- Determine owner from Last User
- Custom weights – Select this radio button to use custom weights to determine the probable owner. These weights can be set by clicking the ellipsis next to the Result weights box to open the Probable Owner Settings window.
The Result weights box displays the custom weights set in the Probable Owner Settings window.
Exclude users list
In the Exclude users list section, select from the following checkboxes:
- Exclude users by list – Enables the Set List of Users to Exclude button
- Exclude locked out users
- Exclude disabled users
Click Set Users to Exclude to open the Probable Owner Settings window:
- User – Enter users in the following format:
Domain\Username
- Add user – Click Add user to add the users entered in the User box to the excluded users list
- Removed selected – Select a user and click Removed selected to remove the user
- Clear list – Click Clear list to remove the list of excluded users
- Select users or groups – Click Select users or groups to open the Select User or Group window and select users or groups to add the excluded users list
- Import from file – Select Import from file to open the Import File Dialog and import files to add to the excluded users list
Output options
In the Output options section, select from the following options:
Get the most probable owner(s)
Get probable owners with relative deviation to the most probable owner – Enables the following option:
- Maximum deviation: [number] percents
Get probable owners limited by probability – Enables the following options:
- Probability threshold [number] percents
- Return at least one probable owner regardless of probability
Select the following checkbox if desired:
- Return the top [number] ranked probable owners
