Applet Mode Permissions
When File System scans are run in applet mode, it means the File System applet is deployed to the target host when the job is executed to conduct data collection. However, the applet can only be deployed to a server with a Windows operating system. The data is collected on the Windows target host where the applet is deployed. The final step in data collection is to compress and transfer the data collected in the SQLite database(s), or Tier 2 database(s), back to the Access Analyzer Console server. If the target host is a NAS device, the File System scans will default to local mode for that host.
Configure the credential(s) with the following rights on the Windows target host(s):
  • Group membership in the local Administrators group
  • Granted the “Backup files and directories” local policy privilege
  • Granted the “Log on as a batch” privilege
  • Granted the "Network access: Restrict clients allowed to make remote calls to SAM" Local Policies > Security Options privilege
Additionally, the credential must have WRITE access to the …\StealthAUDIT\FSAA folder in the installation directory on the target host/proxy server as well as on the Access Analyzer Console server. This is required by either the user account running the Access Analyzer application, when manually executing jobs within the console, or the Schedule Service Account assigned within Access Analyzer, when running jobs as a scheduled tasks.
Remember, Remote Registry Service must be enabled on the host where the applet is deployed (for Applet Mode or Proxy Mode with Applet scans) to determine the system platform and where to deploy the applet.
CAUTION: The local policy, “Network access: Do not allow storage of passwords and credentials for network authentication” must be disabled in order for the applet to start.
Sensitive Data Discovery Auditing scans require .NET Framework 4.7.2 or later to be installed on the server where the applet is to be deployed in order for Sensitive Data Discovery collections to successfully occur.
When running Access Auditing (FSAA) and/or Sensitive Data Discovery Auditing scans, the credentials within the Connection Profile assigned to the File System scans must be properly configured as explained above. Also the firewall rules must be configured to allow for communication between the applicable servers.
See the Applet Mode Port Requirements topic for firewall rule information.
