AD_CertificateRequests Job
The AD_CertificateRequests job provides details about certificate requests, and highlights any that are expiring soon.
Parameter Configuration​
Use the Configuration section on a Job's overview page to modify any customizable parameters used by analysis tasks in the job. See the Parameter Configuration topic for instructions on how to edit parameters on a job overview page.
The AD_CertificateRequests job has the following configurable parameter:
  • Number of days to consider a cert close to expiration (default 60)
This parameter defines what counts as an expiring certificate. The Certificate Expiration analysis task uses it to identify certificates expiring within the specified number of days. The default is 60 days.
Analysis Tasks for the AD_CertificateRequests Job​
Navigate to the Active Directory > 7.Certificate Authority > AD_CertificateRequests > Configure node and select Analysis to view the analysis tasks.
  • Suspicious Principal Certs – Identifies certificates that show the requester requesting a certificate for a different principal
  • OID in Template – Identifies certificates where the Extended Key Usage (EKU) Object Identifier (OID) is in the template OID
  • Certificate Expiration – Identifies certificates that expire in the next number of days set by the customizable parameter. The default number of days is 60. Creates the SA_AD_CertificateRequests_ExpiringSoon table accessible under the job’s Results node.
  • Authentication Based Certificates – Identifies certificates that contain Authentication based OIDs. Creates the SA_AD_CertificateRequests_AuthenticationBasedCertiifcates view accessible under the job’s Results node.
In addition to the tables and views created by the analysis tasks, the AD_CertificateRequests job produces the following pre-configured report:
Expiring Certificate RequestsCertificate hygiene is another aspect of a Certificate Authority that should be monitored. This report shows you all certificate information on certificate requests, expired, and expiring certificates.NoneThis report is comprised of three elements:
  • Stacked Bar Chart – Displays expiring certificates by Certificate Authority
  • Table –Provides a summary of expired and expiring certificates
  • Table –Provides details on expiring certificates
