6.Broken Inheritance > AD_BrokenInheritance Job
The AD_BrokenInheritance Job reports on all locations within Active Directory where inheritance is broken within the targeted domains.
6.Broken Inheritance Job Group in the Jobs Tree
The AD_BrokenInheritance Job is located in the 6.Broken Inheritance Job Group.
Analysis Tasks for the AD_BrokenInheritance Job​
Navigate to the Active Directory Permissions Analyzer > 6.BrokenInheritance > AD_BrokenInheritance > Configure node and select Analysis to view the analysis tasks.
  • Broken Inheritance Details – Creates the SA_AD_BrokenInheritance_Details table accessible under the job’s Results node
  • Broken Inheritance Summary – Creates an interim processing table in the database for use by downstream analysis and report generation
In addition to the tables and views created by the analysis tasks, the AD_BrokenInheritance Job produces the following pre-configured report.
Broken Inheritance by DomainThis report highlights instances of broken inheritance on Active Directory objects. This information is summarized by domain.NoneThis report is comprised of three elements:
  • Bar Chart – Displays broken inheritance by domain
  • Table – Provides summary of broken inheritance by OU
  • Table – Provides details on broken inheritance
