FS_RestoreInheritance Job
The FS_RestoreInheritance job is designed to restore inheritance to previously quarantined files.
Analysis Tasks for the FS_RestoreInheritance Job
Navigate to the FileSystem > Cleanup > 3. Quarantine > FS_RestoreInheritance > Configure node and select Analysis to view the analysis tasks.
- Determines candidates for restored inheritance – Creates the SA_FS_RestoreInheritance_CandidatesView table accessible under the job’s Results node
Action Tasks for the FS_RestoreInheritance Job
Navigate to the FileSystem > Cleanup > 3. Quarantine > FS_RestoreInheritance > Configure node and select Actions to view the action tasks.
CAUTION: Do not enable the action unless it is required. Disable the action after execution to prevent making unintended and potentially harmful changes to Active Directory.
CAUTION: Do not modify the action task. The action task is preconfigured for this job.
The following action tasks are deselected by default:
- Restore Permissions – Restores permission inheritance to quarantined files where activity has occurred
