Output for Monitored Hosts
Once a host is being monitored the event stream can be sent to multiple outputs.
Output Properties Overview
Configured outputs are grouped under the host. You can have multiple outputs configured for a host. The host event outputs are:
  • File – Creates an activity log as a TSV or JSON file for every day of activity
  • Syslog – Sends activity events to the configured SIEM server or Netwrix Threat Manager, where supported
Add File Output​
Step 1 – On the Monitored Hosts tab, select the host you want and click Add Output.
Step 2 – Select File from the dropdown menu. The Add New Output window opens.
addnewoutputfile
Step 3 – Configure the tabs as desired.
Step 4 – Click Add Output to save your settings. The Add New Output window closes.
The new output displays in the table. Click the Edit button to open the Output properties window to modify these settings. See the Output Types topic for additional information.
Add Syslog Output​
Step 2 – Select Syslog from the dropdown menu. The Add New Output window opens.
addnewoutputsyslog
