Predefined Script Variables
These are created by the script execution engine, and, in the case of all but $$RESULT$$, are pre-populated with the values supplied in the Credentials Key. They can be used in the script where required.
  • $$USERNAME$$ - the user name used for initial ssh / telnet connection
  • $$PASSWORD$$ - the password used for initial ssh / telnet connection
  • $$USERNAME2$$ - the second level (admin / privilege) user name
  • $$PASSWORD2$$ - the second level (admin / privilege) password
  • $$RESULTS$$ - the variable whose contents are used as the ‘result text’ of the script.
NOTE: Using multiple capturing commands with the same variable will result in the data being appended to the existing value.
Script Commands
A script command consists of one or more parts separated by a comma. Generally the format order is CommandText,[VariableName],[Option],[Command] where the portions in square brackets are optional and depend on the command.
Example
MorePrompt,-- More --
ExcludeMatchesWithComment,*** uptime line removed ***,uptime
Send,\x19
Send,$$PASSWORD$$\r\n
ExecuteAndCapture,$$RESULTS$$,ls -al
Notes
All Commands are automatically followed by the Newline character, except for the Send command where this must be specified explicitly. This is to allow sending single characters in response to menu options etc.
Commands may occur multiple times, for example to exclude multiple matching lines.
Comment Line
Use of # at the start of a script line will render the following text as a comment only e.g. # For information only - describes the behavior of the login script.
Capture
Captures the data received in the next 5 seconds into the named variable. Example to capture the login banner when placed at the head of a script e.g. Capture,$$BANNER$$
CaptureTimed
Captures the data received in the specified number of seconds into the named variable. Example to capture the login banner when placed at the head of a script where this takes up to 10 seconds to appear e.g. Capture,$$BANNER$$,10
Excludes lines matching the given regex from the output text, for example use this to exclude lines with an uptime value which would otherwise be considered a change e.g. ExcludeMatchesWithComment,*** uptime line removed ***,uptime
Execute
Executes the given command and waits for one of the prompts in the received data e.g. Execute,ls –al
ExecuteAndCapture
Executes the given command and waits for one of the prompts in the received data. Captures the result into the given variable e.g. ExecuteAndCapture,$$WHOAMI_RESULT$$,whoami
FileHashPath
Defines the name and path for the NNT*FILEHASH binary to use for Agentless FIM. General best practice is to locate the NNT_FILEHASH binary in the */usr/bin_ folder with execute permissions set for the user account assigned to Change Tracker e.g. FileHashPath,/usr/bin/NNT_FILEHASH_LINUX_X64
HashMatchesWithComment
Hashes lines matching the given regex in the output text using a SHA256 hash, for example to hide passwords. Prefixes the hash with the comment if present e.g. HashMatchesWithComment,*** password hashed *** ,password
MorePrompt
Watches for the given ‘more’ prompt text in the response and sends the given text in reply e.g. MorePrompt,--More--,\n
Replace
Replaces the given string in the received data with the specified replacement e.g. to replace all escape characters with: Replace,\x1B,-
ReplaceCtrl
Replace all ctrl characters with the specified replacement (See also: StripCtrl below) e.g. ReplaceCtrl,-
Send
Sends the specified characters and continues immediately. Note that control characters are represented as their ASCII hex values in the standard notation \xNN, where NN is the hex value of the character (see Wikipedia’s Control Code Chart article for additional information) e.g. to send CTRL-Y character: Send,\x19
SendCapture
Sends the specified characters and captures the data received in the next 5 seconds into the named variable e.g. to pick a menu item ‘L’ and capture the result: SendCapture,$$RESULT$$,L
SendCaptureTimed
Sends the specified characters and captures the data received in the specified number of seconds into the named variable. e.g.to pick a menu item ‘L’ where the response takes 20s to appear and capture the result e.g. SendCapture,$$RESULT$$,20,L
Sleep
Pauses script execution for the given number of seconds e.g.: Sleep,5
StripCtrl
removes all ANSI control characters from the returned data. Format is StripCtrl,ON or StripCtrl,OFF
WaitFor
Waits for the given text in the received data e.g.: WaitFor,Credentials
WaitForPrompt
Waits for any of the prompts specified from the console Prompts list or the AddPrompt commands
