title: Baseline Policy Wizard sidebar_label: Baseline Policies description: Create new baseline policies using the ChangeTracker Baseline Policy Wizard for configuration monitoring and security baseline management.
New Policy:
Start a new Baseline Policy Wizard and provide a name for your new Policy.
Data Collection:
baselinedatacollection
Define the Data Collection template to be used for gathering baseline configuration data. This can be a new template, or an existing template can be re-used. The following configuration elements to be used in Baseline policy, File System Integrity, Installed Software and Updates, Running Processes and Service states, Local User Accounts, Command Output (also allows Firewall and Router configs to be baselined) and Open Network Ports (using a local netstat or equivalent on the Host or using an NMAP Network Scan)
Specify Source:
A single device is selected to act as the Source for Baseline Policy data. This should be a 'Control' device or simply a "Representative Example" of what your ideal device configuration should be, e.g. a device that has been patched and hardened exactly as you would like every similar device to be
NOTE: The selected Source device must be enabled as a "Baseline Source". You can do this via the Settings > Agent and Device screen, select the required Device click Edit. There are technical reasons why this is disabled by default; in the interests of storage and performance efficiency, it is not desirable to have every Device sending Baseline Events to the Hub unless needed.
baselinesource
Another important decision is whether you want to include changes from Member Devices when you come to make future changes to your Baseline Policy. By default, the Source device is the single source of configuration items, both for the initial creation of the policy and going forwards, for any changes needed to the Baseline, for example, after patching when versions of software items may need to be updated. In certain situations, it may be convenient to also include changes to Member Group devices too, in which case you can check this box.
baselinespecifymembers
Specify Member:
A single device is selected to act as an initial target against which the Baseline Policy Report can be run. The Wizard will build a Device Group for both the Source Device and the Member Device which in turn allows the Wizard to build a Baseline Report, see later section
Awaiting Device:
At this stage of the Baseline Wizard, we have a Source Device selected and a Data Collection template established. The Source Device Agent will call into the Hub and collect the new instruction to gather and report back on the configuration data collected.
Awaiting Data:
Gathering the Baseline configuration data will take anything from 90 seconds to several minutes, depending on the nature or resources of the Source Device and the scope of the Data Collection template defined. Be patient, but you can check progress using the Check Now button.
baselinechecknow
Add Rules:
This is the penultimate stage where you get to choose which configuration elements will form the Baseline Policy and how, in terms of the Rule Options selected.
The Rule Options are what makes the Baseline Policy feature in Change Tracker so powerful. A basic compare of a Device to a predefined set of configuration rules is OK in some circumstances but rule logic is necessary to convey the other requirements needed in a Baseline Policy.
