title: Installing Express Agent Solaris sidebar_label: Solaris Installation description: Install ChangeTracker Express Agent on Solaris SPARC and Intel systems with ultra-portable agent features for platform monitoring.
Installing Express Agent for Solaris (SPARC and Intel)
The Change Tracker Express Agent is a reduced feature but ultra-portable Agent provided for use on any platform where support for .NET (and Mono) is not provided.
Unlike the standard Gen 7 agent, the Express Agent does not require a .NET/Mono runtime. The Express Agent is provided as an pkg package, downloaded from NNT Members Area and installed using pkg commands.
pkgadd -ivh nnt-changetracker-expressagent-2.0.1.3-25.ppc.pkg
Once the package is installed the HubDetails.xml can be created using a configuration script. The configure-expressagent.sh and is found within the installation directory - /opt/nnt/expressagent.
bash /opt/nnt/expressagent/configure-expressagent.sh
Welcome to the NNT ChangeTracker Express Agent Configuration script
Hub URL [https://localhost/api/] : https://IPADDRESS-SERVERNAME:PORT/api/
Agent username [agent] : agent
Agent password : passWord121
Agent config path [/var/nnt/expressagent] : /var/nnt/expressagent
The Express Agent will be configured with the following settings :
Hub URL : https://localhost/api/
Agent user : agent
Agent password : <hidden>
Config path : /var/nnt/expressagent
(missing or bad snippet)
Scripted Installation of Gen 7 Express Agent PKG Installer
As with all other agents, the installation process can be scripted.
bash /opt/nnt/expressagent/configure-expressagent.sh https://IPADDRESS-SERVERNAME:PORT/api/ agent passWord121 /var/nnt/expressagent
