System Settings Glossary
Complete glossary of System Settings special attributes and a description of each.
Description | Default/Sample Value | Comments |
AgentOfflineGracePeriod | 300 | Number of Seconds for Agent offline reporting |
BaseUrl | https://192.168.2.160/ | System URL |
CreateDefaultGroups | Yes | Suppress re-creation of default Groups on startup |
CreateDefaultQueries | Yes | Suppress re-creation of default Queries on hub startup |
DaysToKeepEventsFor | 120 | Number of Days to keep events in MongoDB |
DeleteDevicesOfflineForSeconds | 86400 | Devices offline for this amount of time are automatically deleted |
EventStatsUnitSeconds | 30 | Granularity (minutes) of events for Dashboard |
IncludeDevicesWithNoEventsInEventExport | Yes | Includes all devices in Reports |
MaxStringLengthForExportCell | 3000 | Controls the max number of characters to be exported for a report |
MongoDumpPath | C:\Program Files\NNT Change TrackerSuite\Gen7\MongoDB\bin | Path to MongoDump Executable |
MinimumFileHashReputation | AssuredGood | Controls the level of Whitelist assurance that maps to a planned event, alternative is AssumedGood which will bias results to give more tolerance to lower file reputations |
PollGracePeriodSeconds | 20 | Number of Seconds for Polled Device grace period for off-line reporting |
ReportAllErrors | Yes | Report on all Errors |
SessionTimeout | 10 minutes (0 to disable) | Minutes before User Session is terminated |
SessionTimeoutWarning | 30 seconds (0 to disable) | Warning before a User Session is terminated |
SyslogUseLocalTime | False | Syslog is sent with UTC time by default, but this setting will send syslogs with local times gathered from the devices the agents run on. |
TextSearchMethod | Text | Search method used, can be set to ‘regex’ to use more precise regular expression match |
