Netwrix Auditor Integration
The integration between Netwrix Change Tracker and Netwrix Auditor allows for any event which Change Tracker collects to be forwarded to Auditor. The type of event forwarded is controlled by the Change Tracker notification profile.
In this example notification profile, unplanned changes for systems in the Windows 2019 Auditor group and compliance reports which are run against the Windows 2019 group will generate notifications that will be pushed to Auditor.
Change events are pushed to Auditor via the it's API. Once in Auditor, these events can be mined with the search functionality. Using the search option, information gathered by Change Tracker can be used to create reports and alerts or it can be merged with data natively gathered by Auditor.
This integration allows Auditor to gather information on the monitored environment that it would not natively be able to collect. For example, monitoring the files of a website for change activity.
Search criteria, like the one above, can be saved to generate reports or alerts.
