Common Troubleshooting Tips
Permission Denied
Check file permissions, especially execute permissions for the user account to be used by the Netwrix Change Tracker Proxy Agent.
[root@IP141-Oracle-Linux-7 ~]# NNT_FILEHASH_LINUX_X64
-bash: /usr/bin/NNT_FILEHASH_LINUX_X64: Permission denied
No File or Directory
Check that the NNT_Filehash has been placed on a path for the user account being used. Use $PATH to show the path variable settings for the user account. You can modify the user path by creating a custom.sh shell script in /etc/profile.d/ or by modifying /etc/bashrc or /etc/profile but reference the appropriate guidance for your platform OS.
-bash: /usr/bin/NNT_FILEHASH_LINUX_X64: No such file or directory
Error While Loading Shared Libraries
Suggests there may be missing dependencies or required libs are not on an executable path for the user account being used.
[[root@IP141-Oracle-Linux-7 ~]# NNT_FILEHASH_LINUX_X64
NNT_FILEHASH_LINUX_X64: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
Check dependencies of NNT Filehash using a ldd NNT_FILEHASH_LINUX_X64
[root@IP141-Oracle-Linux-7 bin]# ldd NNT_FILEHASH_LINUX_X64
linux-vdso.so.1 => (0x00007ffdca7f1000)
libstdc++.so.6 => not found
libm.so.6 => /lib64/libm.so.6 (0x00007ff4efd3a000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007ff4efb24000)
libc.so.6 => /lib64/libc.so.6 (0x00007ff4ef762000)
/lib64/ld-linux-x86-64.so.2 (0x000055e3dd177000)
Here the libstdc++.so.6 file is reported as ‘not found’, while all other dependencies have been located OK.
- Check if libstdc++.* is present on the platform to be monitored using command find / -name libstdc++.*
- If the file is located then it will be necessary to either copy the file to the standard default path, e.g. /usr/bin, or at least create a link from the path to the file
- If the libstdc file is not located on this host, please run the find command on any other similar servers, especially any with compiler capabilities. If located, please take a copy of the file, move it to all other servers and place it on the /usr/bin path
- if libstdc++ does not exist anywhere within your server estate, then it will be necessary to get the binary from the Manufacturer repo or contact Netwrix Support
