Delete Workflow
You can delete a single workflow or a group of workflows within the scope (Global or other):
  • To delete all workflows in the scope, in the Workflows list select the necessary Name (scope) and click Delete on the right.
  • To delete specific workflow, do the following:
    1. In the list of workflows, locate the workflow you need.
    TIP: You can use Search in the upper right corner of the window.
    1. Click the link in the Name column for the required workflow (Global for Google Drive in the figure below):
    workflow_delete_single_thumb_0_0
    1. This will open the list of workflows for selected scope. Select the workflow you need and click Delete.
    workflows_category_list_thumb_0_0
Edit Workflow settings
To edit the workflow settings, do the following:
  1. On the Workflows tab, click the row that contains the required workflow.
  2. In the list of workflows displayed, click the one you need.
  3. You will be forwarded to the configuration window where you can modify workflow conditions, rule conditions and actions, as described in the Configuring Workflows Using Advanced Dialog section.
add_workflows_rules_list_thumb_0_0
