Notifications
Notification
A notification can be configured to be sent to a given user on a regular basis at specified times,
through the
SendNotificationsTask
as part of a job.
Examples
The following example defines a notification to inform/remind managers of the arrival of new employees in their team.
The notification is built based on:
- the template
Notification.cshtml
; - the styles
Notification.css
; - the subject defined by
TitleExpression
The notification is sent for each new user, i.e. each user whose contract start date is in the future. The notification is sent to the new user's manager(s).
The notification will be sent again as a reminder after 7 days, by the next SendNotificationsTask
<Notification Identifier="New_Directory_User" OwnerEntityType="Directory_User" RazorTemplate="./Template/Notification.cshtml" CssTemplate="./Template/Notification.css" TitleExpression="C#:user:return "New Employee";" QueryFilterExpression="C#:user:return $"join MainRecord r where r.ContractStartDate > \"{DateTime.UtcNow.ToString("yyyy-MM-ddTHH:mm:ssZ")}\"";" RecipientMailBinding="Directory_User:MainRecord.Organization.Manager.MainRecord.Email" ReminderInterval="10080" />
Properties
Property | Details |
CssTemplate optional | Type String Description Path to the css file that defines the styles for the email. Note: the path must be relative to the configuration folder, and the file must be inside it. Note: required when creating a customized notification with <Notification.../> . |
Identifier required | Type String Description Unique identifier of the notification. |
OwnerEntityType required | Type Int64 Description Identifier of the entity type that represents the population affected by the notification, and the variable type used in TitleExpression and QueryFilterExpression . |
QueryFilterExpression optional | Type String Description C# expression that returns a Usercube Squery in order to define the sending condition of the notification. The expression's variable type is defined in OwnerEntityType . See more details on C# expressions. |
RazorTemplate optional | Type String Description Path to the Razor cshtml file that defines the email's body template. Note: the path must be relative to the configuration folder, and the file must be inside it. Note: required when creating a customized notification with <Notification.../> . |
RecipientMailBinding optional | Type Int64 Description Binding of the property that corresponds to the email addresses that will receive the notification. |
ReminderInterval default value: 0 | Type Int32 Description Time period (in minutes) after which a reminder of the original notification should be sent. Note: the notification reminder will be sent by the first SendNotificationsTask after the reminder interval is exceeded. |
TitleExpression optional | Type String Description C# expression that defines the email's subject. The expression's variable type is defined in OwnerEntityType . See more details on C# expressions. |
AccessCertificationNotification
Reminder notification concerning access certification.
Examples
The following example sends after 2 days a reminder notification to users who were already notified
by the native notification for access certification (on resources from Directory_User
) and have
not yet performed the action. The email's content and styles are those from the original
notification, but the subject is overridden by TitleExpression
here.
<AccessCertificationNotification Identifier="AccessCertification_Directory_User_Reminder" OwnerEntityType="Directory_User" TitleExpression="C#:user:return "Reminder: You have pending access certification items to review";" ReminderInterval="2880" />
The following example sends the exact same notification as the previous example, but with different templates for the content and the styles.
<AccessCertificationNotification Identifier="AccessCertification_Directory_User_Reminder" OwnerEntityType="Directory_User" RazorTemplate="./Templates/AccessCertification_Reminder.cshtml" CssTemplate="./Templates/AccessCertification_Reminder.css" TitleExpression="C#:user:return "Reminder: You have pending access certification items to review";" ReminderInterval="2880" />
Properties
OwnerEntityType required | Type String Description Identifier of the entity type that represents the population affected by the notification, and the variable type used in TitleExpression . |
CssTemplate optional | Type String Description Path to the css file that defines the styles for the email. Note: the path must be relative to the configuration folder, and the file must be inside it. Note: when no template is specified, the reminder notification will use the same template as the original notification. |
RazorTemplate optional | Type String Description Path to the Razor cshtml file that defines the email's body template. Note: the path must be relative to the configuration folder, and the file must be inside it. Note: when no template is specified, the reminder notification will use the same template as the original notification. |
Notifications (Typed)
Reminder notification concerning access certification.- #### ManualProvisioningNotification Reminder notification concerning manual provisioning.- #### ProvisioningReviewNotification Reminder notification concerning provisioning review.- #### RolePolicyNotification Reminder notification concerning role model tasks.- #### RoleReviewNotification Reminder notification concerning role review.
Examples
by the native notification for manual provisioning (on resources from Directory_User
) and have not
yet performed the action. The email's content and styles are those from the original notification,
here.
<ManualProvisioningNotification Identifier="ManualProvisioning_Directory_User_Reminder" OwnerEntityType="Directory_User" TitleExpression="C#:user:return "Reminder: You have pending resources to manually provision";" ReminderInterval="2880" />
<ManualProvisioningNotification Identifier="ManualProvisioning_Directory_User_Reminder" OwnerEntityType="Directory_User" RazorTemplate="./Templates/ManualProvisioning_Reminder.cshtml" CssTemplate="./Templates/ManualProvisioning_Reminder.css" TitleExpression="C#:user:return "Reminder: You have pending resources to manually provision";" ReminderInterval="2880" />
Properties
Examples
by the native notification for provisioning review (on resources from Directory_User
) and have not
here.
<ProvisioningReviewNotification Identifier="ProvisioningReview_Directory_User_Reminder" OwnerEntityType="Directory_User" TitleExpression="C#:user:return "Reminder: You have pending resources to review";" ReminderInterval="2880" />
<ProvisioningReviewNotification Identifier="ProvisioningReview_Directory_User_Reminder" OwnerEntityType="Directory_User" RazorTemplate="./Templates/ProvisioningReview_Reminder.cshtml" CssTemplate="./Templates/ProvisioningReview_Reminder.css" TitleExpression="C#:user:return "Reminder: You have pending resources to review";" ReminderInterval="2880" />
Properties
Properties
Property | Type | Description |
Identifier optional | String | Unique identifier of the notification. |
Examples
by the native notification for role review (on resources from Directory_User
) and have not yet
performed the action. The email's content and styles are those from the original notification, but
here.
<RoleReviewNotification Identifier="RoleReview_Directory_User_Reminder" OwnerEntityType="Directory_User" TitleExpression="C#:user:return "Reminder: You have pending roles to review";" ReminderInterval="2880" />
<RoleReviewNotification Identifier="RoleReview_Directory_User_Reminder" OwnerEntityType="Directory_User" RazorTemplate="./Templates/RoleReview_Reminder.cshtml" CssTemplate="./Templates/RoleReview_Reminder.css" TitleExpression="C#:user:return "Reminder: You have access pending roles to review";" ReminderInterval="2880" />
Properties
NotificationTemplate
A notification template is used to overwrite the subject and/or body of a native notification with personalized templates.
Usercube natively sends notifications for usual cases.
These native notifications are based on cshtml templates available inside the Runtime
folder. If
the provided templates do not meet your exact needs, then they can be replaced by personalized
notification templates. See the
Native Notifications topic
for additional information.
Examples
The following example overwrites the template of the notification provided by Usercube for role review.
script in the command line.
<NotificationTemplate Identifier="WorkflowReviewRolesSummary" SubjectTemplate_L1="./Templates/Notification_RoleReview_Subject.cshtml" BodyTemplate_L1="./Templates/Notification_RoleReview_Body.cshtml" />
The following example defines a template for the notification's subject.
// WorkflowReviewRolesSummary_Subject.cshtml
@using Usercube.Application.DeltaProvisioning.Notification
@model WorkflowReviewRolesSummary
Review Roles - @(@Model.AssignedCompositeRoles.Any() ? @Model.AssignedCompositeRoles.FirstOrDefault().Owner.FullName : @Model.AssignedSingleRoles.FirstOrDefault().Owner.FullName)
Properties
BodyTemplate_L1 optional | String | Path to the Razor cshtml file that defines the email's body template in language 1 (up to 16). NOTE: The path must be relative to the configuration folder, and the file must be inside it. |
Identifier required | String | Identifier of the native notification to adjust, among: - BlockedProvisioningInformations - OneWayPasswordReset - PendingAccessCertificationModel - PerformManualProvisioningSummary - RolePolicySummary - RunJobNotification - TwoWayPasswordReset - WorkflowReviewProvisioningSummary - WorkflowReviewRolesSummary |
SubjectTemplate_L1 optional | String | Path to the Razor cshtml file that defines the email's subject template in language 1 (up to 16). NOTE: The path must be relative to the configuration folder, and the file must be inside it. |
