Sql
This connector exports data from one of various Database Management Systems.
This page is about:
- Database/Generic SQL;
- Database/Microsoft SQL Server;
- Database/MySQL;
- Database/ODBC;
- Database/Oracle;
- Database/PostgreSQL;
- Database/SAP ASE.
A database is a collection of relational data which represents some aspects of the real world. A database system is designed to be built and populated with data for a specific task.
A Database Management System (DBMS) is a software for storing and retrieving users' data while considering appropriate security measures.
Some popular DBMS systems are Microsoft SQL Server, MySQL, Oracle, PostgreSQL, etc.
The goal of this connector is to connect to a DBMS and execute a query in order to export a table.
Prerequisites
- the configuration of a DBMS system;
For example for Microsoft SQL Server 2017, see Microsoft's documentation for planning a SQL Server installation, the SQL Server installation guide and (optionally) downloading SQL Server Management Studio (SSMS).
- creating a database
MyDb
with several tables and data so the user can query on the database, for testing purposes.
Export
This connector exports the content of any table from an SQL database and writes it to a CSV file.
Configuration
connection
in the UI and/or the XML configuration, and in the appsettings.agent.json > Connections
section:
"Connections": {
"<ConnectionIdentifier>": {
- be unique.
- not begin with a digit.
- not contain
and_
The following example configures the connection to Microsoft SQL Server and exports the table
UC_Connectors
from the databaseMyDb
:appsettings.agent.json
"Connections": {
"SqlExport": {
"ConnectionString" : "data source=.;Database=MyDb;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;",
"SqlCommand": "SELECT * FROM [MyDb].[dbo].[UC_Connectors]"
Setting attributes
Name | Details |
ConnectionString required | Type String Description Connection string of the database. See the specific syntax. |
Timeout optional | Type Int32 Description Time period (in seconds) after which the request attempt is terminated and an error is generated. |
SqlCommand optional | Type String Description SQL request to be executed. Note: when not specified and SqlFile neither, then all the entity type mappings of this connector will be exported. |
SqlFile optional | Type String Description Path of the file containing the SQL request to be executed. Note: ignored when SqlCommand is specified. Note: when not specified and SqlFile neither, then all the entity type mappings of this connector will be exported. |
CsvEncoding default value: UTF-8 | Type String Description Encoding of the file. See the list of available encodings. |
ProviderClassFullName optional | Type String Description Invariant name to register the provider. Note: required when querying a DBMS other than Microsoft SQL Server. |
ProviderDllName optional | Type String Description DLL, i.e. name and extension, to be loaded by the connector. Note: the DLL must be in the Runtime folder. Note: required when querying a DBMS other than Microsoft SQL Server. |
IsolationLevel default value: ReadUncommitted | Type String Description Locking behavior of the transaction: ReadUncommitted ; ReadCommitted - used for the databases that do not support the ReadUncommitted level, like Oracle databases. |
Connect to other DBMS
Connect to a DBMS other than Microsoft SQL Server by proceeding as follows:
Download and extract the package.
For MySQL, download the package from MySql.Data.
Copy the DLL file (corresponding to the correct .Net version) to the
Runtime
folder.For MySQL, the DLL is
MySql.Data.dll
Get the value required for
andProviderDllName
for a DBMS handled by Usercube's packages, by accessing the package page;
For MySQL:
for another DBMS, by accessing the DBMS' documentation for .Net and finding a class with Factory in its name.
If MySQL were not part of Usercube's packages, you would see MySqlClientFactory.
The Factory class must derive from DbProviderFactory. After verification, the
can be found in the Inheritance Hierarchy of the class.For MySQL, here
ProviderDllName
is MySql.Data.dll andProviderClassFullName
is MySql.Data.MySqlClient.MySqlClientFactory.Then the following example configures the connection to MySQL and exports the table
UC_Connectors
(the SQL command is insidemySql.sql
):appsettings.agent.json
"Connections": {
"SqlExport": {
"ConnectionString" : "Server=localhost;Database=MyDb;Uid=root;Pwd=secret",
"SqlFile": "C:/identitymanagerDemo/Conf/Sql/mySql.sql",
"ProviderClassFullName": "MySql.Data.MySqlClient.MySqlClientFactory",
"ProviderDllName": "MySql.Data.dll"
}Another example for ODBC:
"Connections": {
"SqlExport": {
"ConnectionString": "Driver=ODBC Driver 17 for SQL Server;Server={YOUR-PC}\\SQLEXPRESS;Database={Database Name};Hostname=Localhost;DBALIAS={Database Alias};trusted_connection=Yes",
"ProviderClassFullName": "System.Data.Odbc.OdbcFactory",
"ProviderDllName": "System.Data.Odbc.dll",
"SqlCommand": "SELECT * FROM {Table Name}",
"IsolationLevel": null
Output details
This connector is meant to generate to the
ExportOutput
folder one CSV file, named <connectionIdentifier>.csv
whose columns correspond to the columns
returned by the SQL query.
Fulfill
There are no fulfill capabilities for this connector.
Authentication
Password reset
This connector does not reset passwords.
Credential protection
- RSA encryption,
configured in the
appsettings.encrypted.agent.json
file; - an Azure Key Vault safe;
Attribute | Naming Convention for the Key in Azure Key Vault |
ConnectionString | Connections--<identifier>--ConnectionString |
SqlCommand | Connections--<identifier>--SqlCommand |
SqlFile | Connections--<identifier>--SqlFile |
CsvEncoding | Connections--<identifier>--CsvEncoding |
ProviderClassFullName | Connections--<identifier>--ProviderClassFullName |
ProviderDllName | Connections--<identifier>--ProviderDllName |
Timeout | Connections--<identifier>--Timeout |
CyberArk is not available for this connector.
Sql Server Entitlements
This connector exports entitlements from Microsoft SQL Server.
This page is about Database/Microsoft SQL Server Entitlements.
Usercube can manage permissions within Microsoft SQL Server, by exporting the server's and databases' principals, i.e. entities that can request Microsoft SQL Server's resources.
SQL Server supports three types of principals:
- logins at the server level;
- users at the database level;
- roles (if any) at either level.
Every principal includes a security identifier (SID).
Prerequisites
the configuration of a Microsoft SQL Server system;
For example, for Microsoft SQL Server 2017, see Microsoft's documentation for planning a SQL Server installation, the SQL Server installation guide and (optionally) downloading SQL Server Management Studio (SSMS);
understanding the concept of principals, roles and permissions;
A little help on that with:
a
ConnectionString
with aLogin
to connect to the SQL Server, where either the login has the sysadmin role, or:- the login has the securityadmin role, in order to export server principals;
- each database to export has a database user attached to the login with at least one role among db_accessadmin, db_owner and db_securityadmin, in order to export database principals.
Securables can also be defined manually for both the server and database principals, but this is more complicated and hence not recommended.
Export
This connector exports from one or several databases to CSV files the following tables:
sys.server_principals
;sys.server_role_members
;sys.database_principals
;sys.database_role_members
This connector exports only in complete mode.
Configuration
connection
section:
"Connections": {
- be unique.
- not contain
and_
The following example connects Usercube to Microsoft SQL Server and exports the principals from the databases
UsercubeDemo
andAdventureWorks2017
"Connections": {
"SqlServerEntitlementsExport": {
"ConnectionString": "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;",
"Databases": [ "UsercubeDemo", "AdventureWorks2017" ]
Setting attributes
Name | Details |
Databases optional | Type String List Description List of databases to be exported. Note: when not specified, all databases from the SQL Server are exported. |
Output details
This connector is meant to generate to the ExportOutput folder the following CSV files:
<connectionIdentifier>_serverPrincipals.csv
;<connectionIdentifier>_serverRoleMembers.csv
;<connectionIdentifier>_databasePrincipals.csv
;<connectionIdentifier>_databaseRoleMembers.csv
For example, if the connection identifier is SqlServerEntitlementsExport, then the file names are
SqlServerEntitlementsExport_serverPrincipals.csv
, etc.
The output files' columns are the columns returned by the SQL query.
Fulfill
Authentication
Password reset
- RSA encryption,
configured in the
Generic SQL
Exports data from a SQL database.
Package Characteristics | Value |
Display Name | Database/Generic SQL |
Identifier | Usercube.SQL@0000001 |
Export | Usercube-Export-Sql.dll |
Fulfill | NONE |
Has Incremental Mode | False |
Publisher | Usercube |
When creating a connection to a database which is not handled by Usercube's packages, you'll need to
fill in the ProviderDllName
and ProviderClassFullName
properties of the
SQL connector using the procedure given in the example.
MySQL
Export data from a MySQL database.
Display Name | Database/MySQL |
Identifier | Usercube.SQL.MySQL@0000001 |
Fulfill | NONE |
ProviderClassFullName | MySql.Data.MySqlClient.MySqlClientFactory |
ProviderDllName | MySql.Data.dll |
To use this package, MySql.Data.dll
needs to be
downloaded from the MySQL website (selecting the
.NET & Mono operating system) and copied to the Runtime
folder.
You can click on the Archives tab to find other versions.
Oracle Database
Export data from an Oracle database.
Display Name | Database/Oracle |
Identifier | Usercube.SQL.Oracle@0000001 |
Fulfill | NONE |
ProviderClassFullName | Oracle.ManagedDataAccess.Client.OracleClientFactory |
ProviderDllName | Oracle.ManagedDataAccess.Core |
For this package, the default isolation level is ReadCommitted.
To use this package, Oracle.ManagedDataAccess.Core
needs to be
downloaded from the Oracle website
(selecting the ODP.NET
release) and copied to the Runtime
folder.
NOTE: The DLL in the "Oracle.ManagedDataAccess" package isn't compatible with .NET 8
PostgreSQL
Export data from a PostgreSQL database.
Display Name | Database/PostgreSQL |
Identifier | Usercube.SQL.PostgreSQL@0000001 |
Fulfill | NONE |
ProviderClassFullName | Npgsql.NpgsqlFactory |
ProviderDllName | Npgsql.dll |
Exports SQL Server Entitlements
Display Name | Database/SQL Server Entitlements |
Identifier | Usercube.SQL.SQLServerEntitlements@0000001 |
Export | Usercube-Export-SqlServerEntitlements.dll |
Fulfill | NONE |
SQL Server
Export data from a SQL Server database.
Display Name | Database/SQL Server |
Identifier | Usercube.SQL.SQLServer@0000001 |
Fulfill | NONE |
