Production-Ready Installation
This guide leads the reader through the steps to install Usercube for production purposes.
1.__Before proceeding__, you should go through the Overview and Requirements sections to make fundamental decisions about Usercube setup, including:
- Whether to install the database within the Usercube Server or on a separated workstation.
- How many Agents will be installed?
- If only one Agent is installed, whether to install it as an integrated agent or a separate agent.
- What end-user authentication methods are to be used?
- What hosting environment is used for the Agent and the Server?
2. You should get the following archives ready:
- Usercube runtime:
runtime_<version>.zip - Usercube database scheme:
Usercube.sqlfrom theSQL_<version>.zip
3. This guide is based on the following choices:
- Usercube Server running with IIS
- Usercube Database connection with Windows authentication
This guide will allow you to extrapolate less common configurations and will provide links to the relevant Technical Configuration sections.
Our examples use the fabled Contoso Corporation as target organization.
What's Next?
The first step consists in creating a Working Directory.
