Provision Salesforce Users' Profiles via SCIM
This guide shows how to provision a user's account profile in a Salesforce system with the SCIM connector.
Prerequisites
This guide supposes that you already have a working synchronization for Salesforce users' accounts, entitlements and links between accounts and entitlements.
Context
In Salesforce, both profiles and permission sets are in the Entitlements entity, whereas they
are not managed the same way: a user account must have a profile and only one, while it can have
zero to several permission sets.
This implies a difference of treatment based on the entitlement's type.
Configuration
In order to handle this special case, Usercube expects, for now, a very precise configuration. A generic configuration element will come soon to be able to customize and apply this special treatment in other cases.
For now, for your EntityType representing Salesforce's Entitlements entity type, you need to
have an entity property with exactly type as identifier:
**<Property Identifier="type" DisplayName_L1="Type" TargetColumnIndex="13" Type="String" />**
And to map it in the Entitlements entity type mapping:
**<Property Identifier="type" ConnectionColumn="type" />**
That is all you need to do. With the next synchronization, all the entitlements will have their
type and then the special treatment can be done for those with the Profile type when
provisioning users' entitlements.
