Write a Template for a Ticket Connector
This guide shows how to write a template that will be used by a Ticket connector to complete the title and the description of the ticket. The information which will be written in the ticket will come from the generated provisioning order and from literal strings written in the template.
Attributes provided by Usercube
| Name | Details |
| Username | Type String Description Is the name of the user for which the ticket is created. |
| ResourceType | Type String Description Is the identifier or the resource type. |
| UsercubeProfileLink | Type String Description Is the link allowing to access the user profile. |
| AddedLinkedEntities | Type List Description Is the list of links to add in the system. |
| RemovedLinkedEntities | Type List Description Is the list of links to remove in the system. |
| DisplayAdd | Type Boolean Description True if there are any links to add. |
| DisplayRemove | Type Boolean Description True if there are any links to remove. |
| Entity | Type Dictionary Description Is the list of values to assign to the resource. |
| ProvisioningOrder.ChangeType | Type String Description Corresponds to the action of the provisioning order (Added, Deleted, Modified). |
| ProvisioningOrder.Changes | Type Dictionary Description Is the list of changes. |
| ProvisioningOrder.Resource | Type Dictionary Description Is the current state of the resource. |
| ProvisioningOrder.Owner | Type Dictionary Description Is the owner of the resource. |
Operations
The template uses the Mustache syntax. Several operations are already provided, but you can find more on this page.
Usercube also provides a way of using conditions with Mustache for the following operations:
>: superior to<: inferior to==: equal to!=: different from
Example
{{#each ProvisioningOrder.Changes}}
{{#ifCond this '==' 'INTERNAL'}}
This account is for an internal employee.
{{else}}
This account is for an external employee.
{{/ifCond}}
{{/each}}
This template goes through all the changes provided by the provisioning order. If any one of them meets the condition for an internal employee, we display the internal employee message. Several messages can be shown if several changes meet the condition.
Template example
Please create a resource "{{ResourceType}}" for user {{Username}}.
**For more information on the user, see: {{UsercubeProfileLink}}**
{{#ifCond ProvisioningOrder.ChangeType '==' 'Deleted'}}
To delete the account, please contact the IT team.
{{/ifCond}}
This is a change: {{this}}
{{/each}}
The resource must have the following values:
{{#Entity.GetEnumerator}}
- {{Key}}: {{Value}}
{{/Entity.GetEnumerator}}
{{#DisplayAdd}}
Add the following links:
{{/DisplayAdd}}
{{#AddedLinkedEntities}}
- {{Name}}
{{#Values.GetEnumerator}}
- {{Value}}: {{Key}}
{{/Values.GetEnumerator}}
{{/AddedLinkedEntities}}
