Usercube-Create-DatabaseViews
Generates entity model SQL views in the Usercube database. All views are prefixed by zz_. This
tool deletes all views starting by zz_ and creates views from the entity model described in the
running configuration.
For every EntityType, a matching SQL view is created from the UR_Resource table.
Example
The following example allows the user to connect to Usercube server at
http://identitymanager.contoso.com, using the ClientId Job and Secret secret, to generate views for
Usercube's database.
./identitymanager-Create-DatabaseViews.exe --api-secret secret --api-client-id Job --api-url "http://identitymanager.contoso.com" --log-level Debug
Arguments
| Argument Name | Details |
| --progress-use-database optional | Type String Description Update progress in the SQL database. |
| --progress-use-database-child-instance optional | Type String Description Initiate child task instance. |
| --progress-use-api optional | Type String Description Update progress with the API. |
| --api-client-id required | Type String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
| --api-secret required | Type String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
| --api-url required | Type String Description URL of Usercube server. |
| --log-level optional | Type LogLevel Description Level of log information among: Verbose; Debug; Information; Warning; Error; Fatal. |
You can explore created views in the Usercube database's Views folder in SQL Server Management Studio
