Usercube-Deploy-Configuration
Retrieves all XML configuration files from a given folder, in order to calculate the configuration items to insert, update or delete in the application.
Examples
Locally
The following example deploys an on-premise configuration via a direct connection to the database through its connection string:
./identitymanager-Deploy-Configuration.exe -d "C:/identitymanager/Conf" --database-connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
Remotely
The following example deploys a SaaS configuration via an HTTP POST request to the server of the remote configuration:
**./identitymanager-Deploy-Configuration.exe -d "C:/identitymanager/Conf" --api-url https://my_usercube_instance.com**
To be able to deploy a SaaS configuration, you must first provide your Usercube administrator with identity information. See how to deploy a SaaS configuration for the first time.
Arguments
| Argument Name | Details |
| --configuration-directory (-d) required | Type String Description Path to the configuration folder. |
| --continuous-deployment (-a) optional | Type No Value Description Enables automatic deployment when saving an XML file. |
| --deployment-slot optional | Type DeploymentSlot Description Type of the targeted server among the slot names provided by NETWRIX' SaaS team. For example: Development, Staging, Production. Note: required when working in a SaaS production environment. |
| --dump-changes-directory optional | Type String Description Path to a directory that will receive the logs of all modifications made to the database. Note: can be used with --simulate-only for an additional security before deploying to production. |
| --enable-saas-checks optional | Type No Value Description Enables the checks necessary to deploy in a SaaS environment. Note: enabled automatically when working in SaaS. This argument can be used when deploying locally in order to anticipate a future SaaS deployment. |
| --force-bindings (-bi) optional | Type No Value Description Forces the recomputation of binding paths in the database. |
| --force-cascade-delete optional | Type No Value Description Enables the deletion or archiving of XML configuration items that require extra care and/or approval, usually for dependency issues. Warning: NETWRIX recommends using this option only when prompted by the deployment tool. |
| --force-categories (-c) optional | Type No Value Description Forces the recomputation of the counters for role categories in the database. |
| --force-expressions (-e) optional | Type No Value Description Forces the recomputation of C# expressions in the database. |
| --force-permissions (-p) optional | Type No Value Description Forces the recomputation of access permissions in the database. |
| --force-translations optional | Type No Value Description Forces the recomputation of the translations for the activity template states and the internal display name properties in the database. |
| --http-client-timeout-supplement optional | Type Int32 Description Duration (in minutes) after which the deployment command times out, in addition to the default 30 minutes. |
| --no-create-index optional | Type No Value Description Disables the creation of indexes related to the configuration. Warning: NETWRIX recommends using this option only when advised by the support team. |
| --reset-database optional | Type No Value Description Deletes the whole database and creates an empty one before deploying. |
| --resource-identity-property optional | Type String Description Overrides the resource identity property used by the SelectUserByIdentityQueryHandler settings. |
| --simulate-only optional | Type No Value Description Computes and previews on the screen all the changes to be made, but without editing the database. |
| --api-client-id optional | Type String Description Login of the account authorized by NETWRIX for configuration export/deployment in a SaaS environment. Note: soon deprecated, rather contact the support team. |
| --api-secret optional | Type String Description Password of the account authorized by NETWRIX for configuration export/deployment in a SaaS environment. Note: soon deprecated, rather contact the support team. |
| --api-url optional | Type String Description URL of the server to export/deploy the configuration to, for remote changes. Note: required when --database-connection-string is not specified. |
| --database-connection-string optional | Type String Description Connection string of the database. Note: required when --api-url is not specified. |
| --product-translation optional | Type No Value Description Path of the JSON file that contains the application's translations. See more details on how to import the product's translations. |
| --scope optional | Type String Description Path of a folder or file to export/deploy, instead of exporting/deploying the whole configuration. |
| --log-level optional | Type LogLevel Description Level of log information among: Verbose; Debug; Information; Warning; Error; Fatal. |
