Usercube-Encrypt-File
In Usercube, files are encrypted by default. This tool encrypts an input file or the InputConsole of a Powershell program or file to save it as an encrypted output file. This task cannot be configured in the configuration.
Examples
Launch the tools with input console (powershell script)
The following example, used in a Powershell script, decrypts the file(s) specified by the
csvResult variable and saves the result in the location specified in resultsFile. The encryption
is made using the certificate's thumbprint, store location and store name.
$csvResult | & ./identitymanager-Encrypt-File.exe --file-cert-thumbprint $certificateThumbprint --file-cert-store-location $certificateStoreLocation --file-cert-store-name $certificateStoreName --output-path $resultsFile
Arguments
| Argument Name | Details |
| --files (-f) optional | Type String Description List of all the files to encrypt. Note: required when the entry is made of files. |
| --output-path (-o) optional | Type String Description Output path to save the encrypted files or input console. |
| --file-cert-thumbprint optional | Type String Description Thumbprint of the certificate when the certificate is in the store. |
| --file-cert-dn optional | Type String Description Subject Distinguished Name of the certificate when the certificate is in the store. |
| --file-cert-store-location optional | Type String Description Store location of the certificate when the certificate is in the store. |
| --file-cert-store-name optional | Type String Description Store name of the certificate when the certificate is in the store. |
| --file-cert-file optional | Type String Description File path of the certificate when the certificate is in a PFX file. |
| --file-cert-password optional | Type String Description Password of the certificate when the certificate is in a PFX file. |
| --log-level optional | Type LogLevel Description Level of log information among: Verbose; Debug; Information; Warning; Error; Fatal. |
