Usercube-Export-EasyVista
This tool is made to export entities from an EasyVista instance to CSV files.
The hardcoded entities named Employees can be fetched directly using the URL of the EasyVista
instance. To export other entities, you have to create a view of your data on EasyVista to be able
to fetch an internalquery.
Examples
Exporting entities by specifying attributes
It is possible to export data by specifying the attribute names to fetch, for each exported table:
--url "https://test-fr-vp-01.easyvista-training.com" --login "usercube" --password "usercube2021" --connection-identifier "ConnectionEasyVista" --attributes "table1=[NAME_FR, LOGIN]|table2=[NAME_EN, PROFIL]|Employee=[EMPLOYEE_ID]" --output-path "C:/EasyVistaExport" --account "{account}" --cookie-path "C:/EasyVistaExport" --log-level Verbose --fetching-urls "HTTPS://test-fr-vp-01.easyvista-training.com/api/v1/50011/internalqueries?queryguid={3226F4FE-F3FC-4301-965A-32E546707BD0}&filterguid={9F3146C5-4EE0-4D1A-A4B9-8DC87A63C4E4}&viewguid={99E2223F-C1E0-4A14-87E8-C39C14325C03}" "HTTPS://test-fr-vp-01.easyvista-training.com/api/v1/50011/internalqueries?queryguid={57667FCD-134B-48A7-A188-CE700EF02C15}&filterguid={B4B3A15D-1DE2-41B5-91A7-A8E8343784E1}&viewguid={DB9C013B-28E0-45C8-A4C2-79E7D43C5421}" --entity-names "table1" "table2"
Exporting entities using entities defined in configuration
It is also possible to export data by specifying the Usercube's server URL, so the export tool automatically fetches the entity type mapping property names linked to the specified connection:
--url "https://test-fr-vp-01.easyvista-training.com" --login "usercube" --password "usercube2021" --connection-identifier "ConnectionEasyVista" --output-path "C:/EasyVistaExport" --account "{account}" --cookie-path "C:/EasyVistaExport" --log-level Verbose --fetching-urls "HTTPS://test-fr-vp-01.easyvista-training.com/api/v1/50011/internalqueries?queryguid={3226F4FE-F3FC-4301-965A-32E546707BD0}&filterguid={9F3146C5-4EE0-4D1A-A4B9-8DC87A63C4E4}&viewguid={99E2223F-C1E0-4A14-87E8-C39C14325C03}" "HTTPS://test-fr-vp-01.easyvista-training.com/api/v1/50011/internalqueries?queryguid={57667FCD-134B-48A7-A188-CE700EF02C15}&filterguid={B4B3A15D-1DE2-41B5-91A7-A8E8343784E1}&viewguid={DB9C013B-28E0-45C8-A4C2-79E7D43C5421}" --entity-names "table1" "table2" --api-url "http://localhost:5000" --api-client-id Job --api-secret secret
For each exported table, there is a resulting CSV file containing exported data.
The server has to be running.
Arguments
| Argument Name | Details |
| --attributes optional | Type String list Description List of attributes to enrich the research. Format is: -at "Table1=[last_name, begin_of_contract, department_id, location_id] | Table2=[profile_id, e_mail]" |
| --fetching-urls required if --entity-names is set | Type String list Description The specific URLs to fetch data, corresponding to entity names. It must be the same length and have the same order as --entity-names. |
| --entity-names required if --fetching-urls is set | Type String list Description The corresponding table names to fetch data, corresponding to fetching URLs. It must be the same length and have the same order as --fetching-urls. |
| --url required | Type String Description EasyVista API Endpoint URL. |
| --account required | Type String Description EasyVista account. |
| --login required | Type String Description Path of the file used for complete synchronization. |
| --password required | Type String Description EasyVista server password. |
