Usercube-Export-Excel
Examples
Exporting a file respecting the default parameters
Consider the file C:/identitymanagerContoso/Sources/hr_example.xlsx with UTF8 encoding, it can be
exported using these command's arguments:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput
The output file(s) will be located in C:/identitymanagerContoso/Temp/ExportOutput/. Their number
corresponds to the number of sheets in the XLSX file and they would be labeled: HREXAMPLE_0.csv,
HREXAMPLE_1.csv, � HREXAMPLE_n-1.csv where n corresponds to the amount of spread sheets of the
XLSX file. The encoding is UTF8 and the separator is ,.
Skipping some file's lines
The possibility to skip lines is made available using the --lines-to-skip argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --lines-to-skip 10
As a consequence, the exported file would include the content of the XLSX file without the ten first lines.
Regex in file name
Considering a generated file following the regex: C:/identitymanagerContoso/Sources/hr_example(.*?).xlsx,
for instance C:/identitymanagerContoso/Sources/hr_example5fH8g1.xlsx, if several files match with the
regex, the executable would use the most recent one.
The regex can be included in the filename and would need to be precised using the --is-regex
argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example(.*?).xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --is-regex
Choosing value to trim
It's possible to precise characters to trim using the --values-to-trim argument:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --values-to-trim e
The CSV output file will see every words beginning and ending by "e" (lower-case, this process is case sensitive) removed of this letter.
Ignoring particular sheets
The --sheets-ignored argument allows the user to specify for each sheet if it should be ignored
during the export. More precisely, a list of true or false arguments should be specified
respectively to the sheets. Let's say the C:/identitymanagerContoso/Sources/hr_example.xlsx file
possesses three sheets, in order to export the first and the last ones the arguments would be:
--raw-files-path C:/identitymanagerContoso/Sources/hr_example.xlsx --not-incremental --connection-identifier HREXAMPLE --output-path C:/identitymanagerContoso/Temp/ExportOutput --sheets-ignored false true true false
Thus, two CSV files would be created corresponding to the the chosen ones: HREXAMPLE_0.csv and
HREXAMPLE_3.csv.
Path Duality and the Not-Launch-Export System
The export executable might be used for a complete or an incremental synchronization. Thus, it
possesses two paths that could be precised - depending on the case - with the --raw-files-path for
complete synchronizations argument or the --path-incremental for incremental ones.
At the end of the day, the --not-incremental argument defines the export behavior: if present it
means a complete synchronization should be performed and the --raw-files-path argument must be
precised; if missing an incremental synchronization would be performed using --path-incremental.
It means that if the user provide the --not-incremental argument and no --raw-files-path, or if
the user doesn't provide --not-incremental nor --path-incremental, the export will not be
launched to prevent any issue (complete data for an incremental synchronization for instance). The
--force-complete argument bypasses this safeguard: during the initialization job for example,
where we want to perform a complete synchronization, even for Excel connections with only an
incremental path.
Arguments
| Argument Name | Details |
| --not-incremental optional | Type No Value Description Specifies the synchronization mode, its presence meaning complete, its absence incremental. |
| --is-regex optional | Type No Value Description The file's name is a regex so we find the last generated corresponding file. |
| --connection-identifier optional | Type String Description Connector's connection identifier. The output file will have this identifier as name. |
| --output-path required | Type String Description Output path for the files generated by the export. |
