Usercube-Fulfill-EasyVista
This executable creates, updates and archives employees in an EasyVista instance.
Examples
Connector specified
Resource types specified
Arguments
| Argument Name | Details |
| --api-client-id required | Type String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
| --api-secret required | Type String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
| --api-url required | Type String Description URL of Usercube server. |
| --url required | Type String Description EasyVista API Endpoint URL. |
| --account required | Type String Description EasyVista account. |
| --login required | Type String Description Path of the file used for complete synchronization. |
| --password required | Type String Description EasyVista server password. |
| --connector required if --resource-typesis not given | Type String Description Id or Identifier of the resource types' connector we want to update the fulfillment state. |
| --resource-types required if --connectoris not given | Type String List Description Id or Identifier of the resource types we want to update the fulfillment state. |
| --certificate-identifier optional | Type String Description Unique key used to retrieve the certificate in Azure Key Vault. |
| --vault optional | Type String Description Vault uri. |
| --vault-connection-string optional | Type String Description Connection string to connect to Azure Key Vault. |
| --batch-size default value: 1000 | Type Int32 Description Number of provisioning orders to wait between each progress report. |
| --task-instance-id optional | Type String Description Id of the task instance which have launch the exe in a job context (for log purposes). |
