Usercube-Fulfill-Scim
This executable creates, updates and deleles entries in an application using the SCIM API.
Examples
Connector specified
--connector "3" --api-url "http://localhost:5000/" --api-client-id "Job" --api-secret "secret" --url "https://scim.contoso.com" --account "12345" --login "Contoso" --password "cOntoSo6789"
--connector "SCIM" --api-url "http://localhost:5000/" --api-client-id "Job" --api-secret "secret" --url "https://scim.contoso.com" --account "12345" --login "Contoso" --password "cOntoSo6789"
Resource types specified
--resource-types "40" "41" --api-url "http://localhost:5000/" --api-client-id "Job" --api-secret "secret" --url "https://scim.contoso.com" --account "12345" --login "Contoso" --password "cOntoSo6789"
--resource-types "SCIM_NominativeUser" "SCIM_Administrator" --api-url "http://localhost:5000/" --api-client-id "Job" --api-secret "secret"--url "https://scim.contoso.com" --account "12345" --login "Contoso" --password "cOntoSo6789"
Arguments
| Argument Name | Details |
| --api-client-id required | Type String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
| --api-secret required | Type String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions. |
| --api-url required | Type String Description URL of Usercube server. |
| --server required | Type String Description URL of the SCIM endpoints of your application, not including the v2. |
| --login optional | Type String Description Specifies the login of the account you may need. |
| --password optional | Type String Description Specifies the password of the account you may need. |
| --application-id optional | Type String Description Specifies the application connection login or the login of your application's id provider. |
| --application-key optional | Type String Description Specifies the application connection password or the password of your application's id provider. |
| --oauth-url optional | Type String Description The server's url when using OAuth2 authentication. |
| --oauth-token optional | Type String Description Specifies the OAuth token to connect to the application. |
| --scim-syntax optional | Type Enum Description Specifies the syntax used for requests body. Has to be one of those values: Salesforce (default value) or CyberArk |
