Usercube-Invoke-ServerJob
Invoke a Job (Server Side)
To launch the job in the Server side only you need to run the executable Usercube-Invoke-ServerJob.exe.
To know the task launch orders in job use the following exe: Usercube-Get-JobSteps.exe
Examples
**.\Usercube-Invoke-ServerJob.exe -g "CleanDatabase" -s secret**
Arguments
| Argument Name | Details |
| --job-identifier (-j) required | Type String Description Job's identifier to be launched. |
| --repair-job (-r) optional | Type No Value Description Bool to Decide launch Synchronization Validation or Provisioning with force. |
| --begin-job-step (-b) optional | Type String Description The step from which the job starts. |
| --end-job-step (-e) optional | Type String Description The step at which the job stops. |
| --task-identifier (-t) optional | Type String Description Specify the identification of the task to be started in the job (only this task will be started). |
| --force-synchronization-provisioning (-f) optional | Type Int64 Description Forces execution when the threshold is reached or exceeded. |
| --task-type (-c) optional | Type String Description The first task found with this type is launched. |
| --task-string-contains (-s) optional | Type String Description Launches all tasks with an identifier containing the given value. |
