Usercube-Protect-X509JsonFile
This tool is used to encrypt a JSON file containing sensitive connection data, for example the
appsettings-agent.json file, with
RSA encryption.
The encryption is based on the information given in your appsettings.json file about either a PFX
file or the location of the
encryption certificate
in the Microsoft store.
This tool Usercube-Protect-X509JsonFile is used to encrypt a whole file, in comparison to the
Usercube-Protect-X509JsonValue
tool that encrypts only a given value. This tool is more appropriate than
Usercube-Protect-X509JsonValue when you have many lines to encrypt.
Examples
The command below encrypts the appsettings.agent.json file from the C:/identitymanagerTraining folder
and creates the appsettings.encrypted.agent.json file in the same folder.
**./identitymanager-Protect-X509JsonFile.exe --input-json-file-path "C:/identitymanagerTraining/appsettings.agent.json" --output-json-file-path "C:/identitymanagerTraining/appsettings.encrypted.agent.json"**
For example it takes this :
"TaskAgentConfiguration": {
"HttpClientTimeoutSupplement": 0
"OpenId": {
"OpenIdClients": {
"Job": "secret"
"DefaultOpenIdClient": "Job"
"PasswordResetSettings": {
"TwoFactorSettings": {
"ApplicationUri": "http://localhost:3000"
"NotificationSettings": {
"Cultures": ["en"]
And it returns this :
"HttpClientTimeoutSupplement": "kxABAEh6CpUOAOMBNPNLKazx9I0vqummv24acN292gonFiK4ov81bjqE2ic+n+HqastXU2aTQcl3IefhEXn9KA2dhnIbDTXB4GhOn9lL9AzUfwKXBr5EBmVy7ggruG2ewpWGK1c3LBJ35km9XvCnzSHLfolZwHNPwM/8b/C6XqSzieoFcO5H92IGJ1lFRboacvp0rO+SkkUv63Ewsk+1MrVLa63oBgWfY6PhMeJvNpWGqCD+I614hB6jE2Li/recwQIPd10XEgFM1OEkZ5ZiO+URxX7MCBe1o20rTaczKR7e7lLQGa/e3Y3i1sFnCm+yRm/lzw0qtDvOtCXlPT13EsHsUunxnR3uH4R6lRBXT30OKobaX7MTQjGkLRChss/GVGCK5w=="
"OpenId": {
"OpenIdClients": {
"Job": "kxABAOkh0BF2GdMedpzmKZZWVWc8IYaiZO2dofmt7lLBP3vMYgLLZYNDyR3x7Ah7tA1r6oSL5gBT3mSFyXB63NJk+QmZqNW1LWdzh+3U+DvNdQw4OfDfFlC5F+nH3/L5iqWc+h1jMlaQBpkqf42Vr8HwFKtqMXLJVXEIyeHSPgHRp1iOjGkNSRNrRQGJ4pVyo0xKmcWsz3qGYf0SnJIzRJ++PcYh/dJgxHAZFsDnV55X3zg72J8teoIEG82GdNjmCV/W4S4edNCYa1gL3KpgDGQq1GEed71Ht1tVYlHlJ4hckE++otQqTgRA2p4nFvo3LmlMag6k4EQRzEk6TOHUlGjUtYgpzMuPqei8/3CRXy5o8YW5R0wVFJJ/jSfYrvR3M9SwJw=="
"DefaultOpenIdClient": "kxABANLI/Qx7X8L1VtIl+FM4RtYlTLLpUUBCp2pucY+jzjlwhbF9fjJhhTP/KmeCj8M2yB4AA1V3AQgcEBvg92I1vCAWXIBgCjz6LUD2yf4FCpACaxNgiBZVAaCELNCgbKDgy9UB1j4sCozpEzReLVtYdOX+KFbGU6zJ808jnrLFMz+YHT4LXMyF94A5Zl86DFT9br6PwR75qImvjDlIUt+7/I8WrT1Nnqn2hXxqzAd1J2W5Xv8Bt9sXFmskSZN9PyOo9EY9t5lVGq++IqjGPWh4vQAXCzIsfRgUfU7PfHKVuSKSHbME1EZwG/FjzOe8B4bO2q/a/qLtGgygyX5ExEkZ/IcrtSZnTdqC83AfyexlEv9Z3wWFAoKGDtI3zhmCZYnuZQ=="
"ApplicationUri": "kxABAFAEx4fWwG/ANPVTf/WGyccDxoR2xCy+x+U3Ny1KkqnOFw+SizePTgINTzBaYHLTHABQD0GWW6U+4qiG6DpcIcdAD0VVnddqB5a+YIE0reufXYhZTrDU/9yeG6aUWIHkLl9UudC/nnW6zMrjChiJhJvT7csFKdgbqUazZT56hR0i6XS36a5h2/tTWhbZTkk1Dil5JP7xUcu5CMWyXMUvGvK8gfQozYxo/DJTOiLrWjg5ION1yx+ZqPhcIUxgYaBjxSpfT6U9YMy5mE9JGqf7W76baS9fOVr3H1DAL02icX29uJAcsw1r9k1rJQIKEhAuqTNeuqF6C6iPHJAsail+iteOJEYgBSACRz7Te4t6Hp7PBs0FfP0WY1oL+1T+p7X+HaO1jAJhE50J2AKhGNXTZfE="
"Cultures": ["kxABAPwTbpFUbP9xT9HyqtTuMLKT9sVD0Qq1kCsI44d12vJEcW2MMy9K5vKakwTPeJpvY6SafELoHc7AjKnh8ZJi0/Yu4dieE5W+5uXY1uaghYJ/2VjimzIsDhvRhm90xUlaMjdFBjx4HAnxBAtEbEjifdGHxZ0L9F305hXSTORj53u76ctCE5D9HPTN3AgLmyIGv5NExwhD4sgppbf6PWjTEZ7yNcoUpkkS4pJ6BMz+PaQo26A2rMP710zQgG72an4XvxSoR3SwSm0fhLCASgYi8YOZw0j/cfxl/LrW1EQ7gyW0/Mw9v1YRNH3DkbWSeHZ3odhDWdaWkzR6yOEt5hO60eM0w8Tjoed30Jwf+enf1rJFStDe/dhg6vjUIaTn6tt1Gw=="]
The previous command can be useful to encrypt, for example, an Active Directory's login used by the agent during the synchronization process.
The login to encrypt is stored in the following format, compliant with the appsettings.agent.json structure:
appsettings.beforeEncryption.json
"Connections": {
"ADExport": {
"Login": "Administrator"
This command writes encrypted values from appsettings.agent.json to
C:/identitymanagerTraining/appsettings.encrypted.agent.json following the
"Connections": {
"ADExport": {
"Login": "kxABAM9LW6vyx3TpDXoU5mKKQAwxxNcH9Q2z+dk+E7BNzrI346fUUiPmnJlOJZNX8bA1sokpDHTJBJngdF8LqVuWhk0t+IBpHE+iRJZ4q6i/CzX/OnpoGEHLSL5gZUixIqn9kul5AbxI38d/aGkCGIeAGY73rf0eQRizB2uR/ObR/H9jm3dHGt3TUNyOH4WqdwrXL0WTeMyfme6O+2PMoGvmjVF04keicuisjj/jROxTcDKe69qjPuCJZabR69CA2qP1TPMDMy/zlg8bzRZKepw8VxI4OpIKrbwhaUTauJMR6URPsOZ54fdocKi3oEyvpm2AhX4YF8GpOw7fBQrPWte/JJFOxgIzH1Kh0d0YhC2ZpMCXexfOlB2Y9afWG/t7rdi4VDsEf8gwj+IJ3HbE0dtIPLw="
Arguments
| Name | Details |
| --input-json-file-path required | Type String Description Path of the input to-be-encrypted json file. |
| --output-json-file-path required | Type String Description Path of the output encrypted json file. |
