Usercube-Send-PasswordNotification
Examples
Manually send a password initialisation mail notification
Consider a user who needs an account in an external system. Consider that this account requires a password.
As an example, we will consider that the id of the resource type mapping associated with the external system is 10, and the id of the assigned resource type associated with the user is 1000.
Once the password is set, we need to communicate this password to the user. We send a mail notification to inform the user.
--password true --assigned-resource-type 1000 --resource-type-mapping 10
For the notification to be sent, the server set at appsettings > ApplicationUri should be
running.
The resource type mapping
should have an associated
password reset setting.
For
the notification to be sent, the password reset settings should at least contain a notified email
binding.
For the notification to make sense, the password reset settings should at least contain a beneficary
full name binding.
Arguments
| Argument Name | Details |
| --assigned-resource-type required | Type String Description Specifies the id of the assigned resource type corresponding to the user and the external system that is being fulfilled with a new password. This can be found in the provisioning order at ProvisioningOrdersList > AssignedResourceTypeId. Example Send a notification for the assigned resource type with id 1000: --assigned-resource-type 1000. |
| --password required | Type String Description Specifies the new password that will be sent by mail. Example Send a notification for the password NewPassword: --password NewPassword. |
| --resource-type-mapping required | Type String Description Specifies the id of the resource type mapping corresponding to the external system that is being fulfilled with a new password. This can be found in the provisioning order at ProvisioningOrdersList > ResourceType > Id, as the resource type and its corresponding resource type mapping share the same id. Example Send a notification for the resource type mapping with id 10: --resource-type-mapping 10. |
| --notification-cc optional | Type Integer Description Specifies an address that should also receive the notification. Example Add admin@acme.admin to the mail CC: --notification-cc admin@acme.admin. |
