Usercube-Upgrade-ConfigurationVersion
This tool is used to upgrade your configuration from your current version entered in settings to the latest version.
Examples
**./identitymanager-Upgrade-ConfigurationVersion.exe --version "5.1.0" --xml-path "C:/identitymanagerDemo/Conf" --output "C:/identitymanagerDemo/Conf2"**
In this example, the configuration files are in the folder "C:/identitymanagerDemo/Conf" and at version "5.1.0". This tools will upgrade all the xml files to the latest version and save them in the folder "C:/identitymanagerDemo/Conf2".
Arguments
Argument NameDetails
--version requiredType String Description Current version.
--xml-path requiredType String Description Current xml configuration folder to migrate.
--output requiredType String Description Path of the folder where the result will be saved.
