appsettings.agent
The appsettings.agent.json file is meant to contain configuration data to be used by the agent to
run Usercube.
It includes:
- connections to the managed systems;
- password reset settings;
- connections to potential additional databases;
- OpenId information;
- specific task configuration.
JSON files can contain any additional information that you might find useful. See the example below.
For example, in order to store the agent's address, we can add:
appsettings.json
"UsercubeAgent": {
"Url": "http://localhost:1234"
}As Usercube does not know any object named
UsercubeAgent, its content will be ignored, but it can still be used to store information for human use.
Supported Sections
| Name | Details |
| Connections optional | Type List of Connections Description Connection information of all the systems managed by this agent, for synchronization and fulfillment configuration. This section contains a subsection for each connection containing the connection's agent settings. { � "Connections": { � "<ConnectionIdentifier>": { "<AgentSetting>": "<Value>": � } } }Example{ � "Connections": { � "Directory": { "Path": "C:\UsercubeDemo\Sources\Directory.xlsx" }, "ServiceNowExportFulfillment": { "Server": "https://INSTANCE.service-now.com/api/now/table", "Login": "LOGIN", "Password": "PASSWORD" } } } See how to configure connections' agent settings via the UI. See more technical details on connections. |
| Databases optional | Type List of Databases Description Names and connection strings of all databases used by the agent through InvokeSqlCommandTask, other than Usercube's database and other than the databases provided in Usercube's available packages. This subsection contains a subsection for each additional database. { � "Databases": { "<DatabaseName>": "<DatabaseConnectionString>" } }Example{ � "Databases": { "UsercubeContoso": "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;" } } |
| OpenId optional | Type OpenId Description OpenId information, i.e. the ClientIds and related ClientSecrets that the agent may use to authenticate to the server in order to launch jobs and tasks. In order to launch jobs and tasks, the profiles related to these OpenId credentials must possess the required permissions. See examples below. |
| PasswordResetSettings optional | Type PasswordResetSettings Description Parameters which configure the reset password process for the managed systems that support it. See examples below. |
| SourcesRootPaths optional | Type String Array Description List of folder paths from which Usercube is allowed to read. This option is used to validate the sources files defined in file-based connections. These paths are case sensitive. Example{ � "SourcesRootPaths": ["C:/identitymanagerContoso/SourceHR", "C:/identitymanagerContoso/SourcesPhone"] } |
| TaskAgentConfiguration optional | Type TaskAgentConfiguration Description Various settings to customize the behavior of some agent tasks. See examples below. |
OpenId
| Name | Details |
| AgentIdentifier required | Type String Description Identifier of the agent, as it is named in the XML configuration. Example With the following configuration: <Agent Identifier="MyAgent" DisplayName_L1="My Agent" URI="https://contoso.com" /> We could have the following setting in the agent's appsettings.agent.json: { � "OpenId":{ � "AgentIdentifier": "MyAgent" } } |
| DefaultOpenIdClient required | Type String Description ClientId that defines the default OpenId pair, from the OpenIdClients section, used by the agent to authenticate to the server. Example{ � "OpenId":{ "OpenIdClients": { "Job": "secret1", "Admin": "secret2", "Agent": "secret3" }, "DefaultOpenIdClient": "Agent" } } |
| OpenIdClients required | Type List of OpenIdClients Description Pairs of ClientIds and non-hashed ClientSecrets, to override the corresponding secrets specified in the XML configuration. Example { � "OpenId":{ "OpenIdClients": { "Job": "secret", "Admin": "secret2" } } } |
| Name | Details |
| EncryptionCertificate required | Type [EncryptionCertificate] Description Location of the public key certificate and the private key used to handle input and output files' encryption. |
| MailSettings optional | Type MailSettings Description Settings for configuring the SMTP server, used to send password reset email notifications. |
| NotificationSettings optional | Type NotificationSettings Description Settings to configure password reset notifications. |
| TokenBuildingSettings optional | Type TokenBuildingSettings Description Settings to build the confirmation token used by the password reset's two-Way mode. The confirmation token is a base-64 encoded JSON Web Token (JWT) token that contains the information required to complete password reset when in two-way mode. It is appended to the confirmation Uri. |
| TwoFactorSettings optional | Type TwoFactorSettings Description Settings to configure the password reset's two-way mode, i.e. the process where Usercube sends emails containing links to users for them to click on it and reset their passwords. |
If you are using the certificate provided in the SDK, the agent will be unable to launch. You must create your own certificate.
Encryption certificate information can be set in one of two ways:
as a PKCS #12 archive (also called Personal Information Exchange file or
.pfxfile) stored in the agent's host file system. The archive contains both the public key certificate and the private key;Name Details File required Type String Description PKCS #12 archive path on the agent's host file system. Example { � "PasswordResetSettings": { "File": "C:/identitymanagerAgentContoso/contoso.pfx" } }Password optional Type String Description PKCS #12 archive password. Example { � "PasswordResetSettings": { "File": "C:/identitymanagerAgentContoso/contoso.pfx", "Password": "oarjr6r9f00" } } -
as a certificate from a Windows' certificate store, identified by its subject distinguished name or its thumbprint. The Windows certificate also contains both the public key certificate and the private key.
Name Details DistinguishedName requiredif Thumbprint is empty Type String Description Subject distinguished name of the certificate. Example { � "PasswordResetSettings": { "DistinguishedName": "UsercubeContoso" � } }StoreLocation required Type String Description Location of the relevant Windows certificate. Example { � "PasswordResetSettings": { � "StoreLocation": "LocalMachine" } }StoreName required Type String Description Name of the relevant Windows certificate. Example { � "PasswordResetSettings": { � "StoreName": "AuthRoot" } }Thumbprint requiredif DistinguishedName is empty Type String Description Thumbprint of the certificate. Example { � "PasswordResetSettings": { "Thumbprint": "6261A70E599642A21A57A605A73B6D2AE7C5C450" � } }
MailSettings
| Name | Details |
| FromAddress requiredif PickupDirectory is empty | Type String Description Email address used by Usercube to send notifications. Example{ � "PasswordResetSettings": { � "MailSettings": { "FromAddress": "no-reply@acme.com", � } } } |
| Host requiredif PickupDirectory is empty | Type String Description SMTP server domain name or an IP address. Note: to be used only when UseSpecifiedPickupDirectory is set to false. |
| Password required | Type String Description Password that Usercube will use to login to the SMTP server. Note: used only when the SMTP server is password-protected and UseSpecifiedPickupDirectory is set to false. |
| PickupDirectory requiredif FromAddress/Host are empty | Type String Description Path to the pickup directory. See more details on the pickup directory feature. Note: to be used only when UseSpecifiedPickupDirectory is set to true. Example{ � "PasswordResetSettings": { � "MailSettings": { "PickupDirectory": "../Mails", � } } } |
| Username required | Type String Description Username for Usercube to login to the SMTP server. Note: used only when the SMTP server is password-protected and UseSpecifiedPickupDirectory is set to false. |
| AllowedDomains optional | Type String Description List of domains to which the SMTP server is authorized to send emails. Domain names must be separated with ;. |
| CatchAllAddress optional | Type String Description Catch-all address that will receive all of Usercube's emails instead of usual users. Note: this is helpful for testing before going live. Example{ � "PasswordResetSettings": { � "MailSettings": { "CatchAllAddress": "administrator@acme.com", � } } } |
| CatchAllCCAddress optional | Type String Description Catch-all address that will receive all of Usercube's emails as cc (carbon copied). Example{ � "PasswordResetSettings": { � "MailSettings": { "CatchAllCCAddress": "administratorcc@acme.com", � } } } |
| Enabled default value: True | Type Boolean Description True to enable email sending. When set to false, no email is sent by Usercube. |
| EnableSsl default value: False | Type Boolean DEPRECATED: EnableSsl won't be supported in the future. Please specify a SecureSocketOption instead. To keep the same behavior as EnableSsl: True, use the setting SecureSocketOption: StartTls. Description True to encrypt communication with the SMTP server. Note: to be used only when UseSpecifiedPickupDirectory is set to false. |
| SecureSocketOption default value: Auto | Type String Description Specifies the encryption strategy to connect to the SMTP server. If set, this takes priority over EnableSsl. None: No SSL or TLS encryption should be used. Auto: Allow the mail service to decide which SSL or TLS options to use (default). If the server does not support SSL or TLS, then the connection will not be encrypted. SslOnConnect: The connection should use SSL or TLS encryption immediately. StartTls: Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server. If the server does not support the STARTTLS extension, then the connection will fail and a NotSupportedException will be thrown. StartTlsWhenAvailable: Elevates the connection to use TLS encryption immediately after reading the greeting and capabilities of the server, but only if the server supports the STARTTLS extension. Note: to be used only when UseSpecifiedPickupDirectory is set to false. |
| Port default value: 0 | Type String Description SMTP server port. Note: to be used only when UseSpecifiedPickupDirectory is set to false. |
| UseDefaultCredentials default value: False | Type Boolean Description True to use the default username/password pair to login to the SMTP server. When set to false, Windows authentication is used. Note: to be used only when UseSpecifiedPickupDirectory is set to false. |
| UseSpecifiedPickupDirectory default value: False | Type Boolean Description True to write emails as local files in the specified PickupDirectory instead of sending them as SMTP packets. See more details on the pickup directory feature. Example{ � "PasswordResetSettings": { � "MailSettings": { "UseSpecifiedPickupDirectory": true, � } } } |
| Name | Details |
| Cultures default value: ["en"] | Type String Array Description List of languages in which reset-password email notifications will be sent, among: fr; en. Example{ � "PasswordResetSettings": { � "NotificationSettings": { "Cultures": ["fr", "en"] } } } |
| Name | Details |
| ValidFor default value: 03:00:00 | Type String Description Validity period of the issued token, and thus of the password reset link. The format must be HH:mm:ss. Example{ � "PasswordResetSettings": { � "TokenBuildingSettings": { "ValidFor": "03:00:00" } } } |
TwoFactorSettings
| Name | Details |
| ApplicationUri required | Type String Description URI of the Usercube application. Note: this helps create the links in the emails for two-way password reset. Example{ � "PasswordResetSettings": { � "TwoFactorSettings": { "ApplicationUri": "http://localhost:5000" � } } } |
| ResetConfirmationUri required | Type String Description Base URI for the password reset link that is sent to the user. The password reset confirmation token is appended to the ResetConfirmationUri. The resulting URI is sent to the user. Example{ � "PasswordResetSettings": { � "TwoFactorSettings": { � "ResetConfirmationUri": "http://localhost:5000/PasswordReset/Activate/?activationCode=" } } } |
| Name | Details |
| HttpClientTimeoutSupplement default value: 0 | Type Integer Description Additional minutes that extend the default timeout (30 minutes) of the HttpClient instance used to send requests to the server. Example Here the total timeout will be 50 minutes: { � "TaskAgentConfiguration": { � "HttpClientAdditionalTimeout": 20 } } |
