Password Management
The Password Management module offers a set of password-related operations on resources of certain types (Active Directory, Microsoft Entra ID (formerly Microsoft Azure AD), Service Now, etc�).
Possible Password Operations
Depending on the target system of the manipulated resource, the following operations are possible:
Password initialization
This operation can be started manually by the user through the UI (with the "Manage Accounts" option on user pages) or automatically during the fulfillment process of the corresponding resource.
It consists of initializing the password and sending a notification containing instructions to a configurable email address.
The password initialization can be done in two different ways:
- One-Way: Usercube sets the initial password, and sends it as part of the instructions notification.
- Two-Way: The instructions notification contains a link to a page where the email recipient initializes the password.
Password change
UI-only operation that allows the user to change the password.
Password reset
UI-only operation that allows the user to reset the password.
Account unlocking
UI-only operation that allows the user to unlock an account that has been blocked due to too many incorrect password attempts.
Possible operations per managed system
Usercube provides a predefined set of possible operations per managed system (which cannot be changed by the configuration).
| Initialize | Change | Reset | Unlock | Notes | |
| Active Directory | YES | YES | YES | YES | Required authentication mode: Basic with SSL or Negotiate |
| LDAP | YES | YES | YES | YES | Required authentication mode: Basic with SSL or Negotiate |
| Microsoft Entra ID | YES | NO | YES | NO | - |
| Service Now | YES | NO | NO | NO | - |
