Create and Assign Profiles
This guide shows how to create in the XML configuration profiles and the appropriate rules to assign these profiles automatically.
Create a Profile
Here is the xml configuration to create a profile in Usercube. See the Profile topic for additional information.
script in the command line.
<Profile Identifier="User" DisplayName_L1="Basic User" DisplayName_L2="Utilisateur de base" />
Automatically Assign Profiles
To automatically assign profiles it is necessary to manipulate the ProfileRuleContext and ProfileRule. See the AccessControlRule and ProfileRuleContext topics for additional information.
<ProfileRuleContext ResourceType="AD_Entry_NominativeUser" SubBinding="Directory_User:Records" IsAppliedToRoot="false"> <ProfileRule Profile="User" /></ProfileRuleContext>
Configure the Usercube-Set-InternalUserProfiles Task
The Usercube-Set-InternalUserProfiles task is mandatory to automatically assign the profile. The task can be selected from the Job provisioning list. See the SetInternalUserProfilesTask topic for additional information.
<SetInternalUserProfilesTask Identifier="SetInternalUserProfiles" DisplayName_L1="Set Internal User Profiles" > <TaskEntityType EntityType="Referentiel_User"/> <TaskResourceType ResourceType="AD_Entry_NominativeUser"/> </SetInternalUserProfilesTask>
Here the TaskEntityType is the reference to connect to Usercube and the ResourceType is the same as in the ProfileRuleContext. Once this configuration is done you can add the task in the job which provisions the Connector AD.
<Job Identifier="AD_Provisioning" DisplayName_L1="AD - Provisioning" DisplayName_L2="AD - Provisioning" Agent="Local"> ...
<SetInternalUserProfilesTask Identifier="SetInternalUserProfiles" DisplayName_L1="Set Internal User Profiles" > <TaskEntityType EntityType="Referentiel_User"/> <TaskResourceType ResourceType="AD_Entry_NominativeUser"/> </SetInternalUserProfilesTask> </Job>
