AccessControlRule
An access control rule gives to a profile a set of permissions on a data set represented by an entity type.
The rule contains filters to restrict its application, and entries to grant or deny the permissions.
Examples
script in the command line.
<AccessControlRule Profile="Administrator" EntityType="Resource" Identifier="Administrator_Resource" DisplayName_L1="Administrator_Resource"> <Entry Permission="/Connectors/SynchronizeSession" CanExecute="true" /> <Entry Permission="/Connectors/ProvisioningSession" CanExecute="true" /></AccessControlRule><AccessControlRule Profile="Administrator" EntityType="Connector" Identifier="Administrator_Connector" DisplayName_L1="Administrator_Connector"> <Entry Permission="/Connectors/Connector/Query" CanExecute="true" /> <Entry Permission="/" /></AccessControlRule><AccessControlRule Profile="Administrator" EntityType="WorkflowInstance" Identifier="Administrator_WorkflowInstance" DisplayName_L1="Administrator_WorkflowInstance"> <Entry Permission="/Workflows/WorkflowInstanceData/Query" CanExecute="true" /> <Entry Permission="/Workflows/WorkflowInstance/Query" CanExecute="true" /> <Entry Permission="/" /></AccessControlRule>
Properties
Property | Type | Description |
DisplayName_L1 required | String | Display name of the access control rule in language 1 (up to 16). |
EntityType required | Int64 | Identifier of the entity type that forms the data set on which the rule's permissions are applied. NOTE: The entity type can be part of the custom entity model, e.g. Directory_User or AD_Entry , or part of the built-in entity model, e.g. AssignedSingleRole or Workflows or AccessCertificationItem . |
Identifier required | String | Unique identifier of the access control. |
Profile required | Int64 | The id of the profile to which the permissions will be given. |
Child Element: Entry
AccessControlEntry grants or denies a permission to a user. Access Control Entries are part of an Access Control Rule that defines the users scope of responsibility in the Usercube UI/Workflows.
If your configuration contains an access control entry with Permission="/"
and
CanExecute="true"
then an error will occur during the configuration deployment, as a profile
should not possess such a big permission.
Properties
CanExecute default value: false | Boolean | Gives permission to execute permission. |
FullAccessProperties default value: false | Boolean | Gives full access to all properties. |
IsPostCondition default value: true | Boolean | If true, the rule is evaluated on the entity after modification. |
IsPreCondition default value: true | Boolean | If true, the rule is evaluated on the entity before modification. |
Notify default value: true | Boolean | True to send notification emails to the rule's recipient profile when executing tasks related to the specified Permission. |
Permission required | Int64 | Linked Permission. |
Priority default value: 0 | Int32 | When a user has several contexts giving him access to the same right, the one with the highest priority is elected. |
PropertyGroup optional | Int64 | Gives the right to read for the PropertyGroup. |
Child Element: Filter
An access control filter restricts the application of the access control rule to a given subset of the data set. The rule will give the specified permissions to the profile only on the parts of the rule's data set for which the filter's condition is met.
Remember, the ViewHistory permission (/Custom/Resources/Entity_Type/ViewHistory) does not work if a filter is added.
<AccessControlRule Profile="Manager" EntityType="Directory_User" Identifier="Administrator_LDAP_Entry_History__" DisplayName_L1="Administrator_LDAP_Entry_History_">
<Entry Permission="/Custom/Resources/Directory_User/ViewHistory" CanExecute="true" />
This condition is actually a comparison expression between two elements:
- The value of a property which is originating from an entity targeted by the rule
- A comparison value that can be constant, or originating from the user profile
Examples
Filter on a constant value
The following example gives to the Administrator
profile certain permissions on user data, but
only concerning users working in the marketing department.
<AccessControlRule Profile="Administrator" EntityType="Directory_User" Identifier="Administrator_Directory_User_Marketing" DisplayName_L1="Administrator_Directory_User_Marketing">
<Filter Binding="MainOrganization.Code" Value="Marketing" />
<Entry Permission="..." ... /> ...
Technically speaking, the filter here says that the rule's permissions apply only on users from
Directory_User
whose Code
of MainOrganization
is Marketing
Filter on the account of the current user
The following example gives to the Manager
profile certain permissions on user data, but only
concerning users from the team managed by the current user.
<AccessControlRule Profile="Manager" EntityType="Directory_UserRecord" Identifier="Directory_UserRecord_Managers" DisplayName_L1="Directory_UserRecord_Managers">
<Filter Binding="Manager.Id" CurrentUser="true" />
Technically speaking, the filter here says that the rule's permissions apply only on the users'
records from Directory_UserRecord
whose Id
of Manager
is the identifier of the account used by
the current user to authenticate to Usercube.
Filter on the context(s) of the assigned profile(s) of the current user
concerning users working in the same department as the current user.
<AccessControlRule Profile="Manager" EntityType="Directory_User" Identifier="Manager_MainDepartment_Directory_UserRecord" DisplayName_L1="Administrator_MainDepartment_Directory_UserRecord">
<Filter Binding="MainDepartment.Id" Dimension="Department" />
</AccessControlRule><Dimension Identifier="Department" DisplayName_L1="Department" EntityType="Directory_Department" ColumnMapping="3" />
Technically speaking, the filter here says that the rule's permissions apply only on the users from
Directory_User
whose Id
of MainDepartment
is the same identifier as the value set for the
Department
dimension of the current user, in at least one of their assigned profiles.
For example, Timothy Callahan is here assigned the Manager
profile with the Department
dimension
set to Treasury/Chief Economist
Thus, with the previous access control rule, Timothy Callahan will get certain permissions on users
whose main department is Treasury/Chief Economist
The following example gives to the RoleOfficerByCategory
profile certain permissions on assigned
single roles, but only concerning the roles of a category assigned to the current user.
<AccessControlRule Identifier="RoleOfficerByCategory_AssignedSingleRole_ReviewRoles" DisplayName_L1="Role Officer - Review Roles" EntityType="AssignedSingleRole" Profile="RoleOfficerByCategory">
<Filter Binding="SingleRole.Category.Id" Category="true" />
Technically speaking, the filter here says that the rule's permissions apply only on the assigned
single roles whose Id
of the Category
of the SingleRole
set for the Category
property of the current user, in at least one of their assigned profiles.
Multiple filters
profile the permission to review the
roles of users from Directory_User
, but only the roles of a category assigned to the current user,
and whose assignment is stated as pending the first approval out of 1, 2 or 3.
<AccessControlRule Identifier="RoleOfficerByCategory_AssignedSingleRole_ReviewRoles_Directory_User_8" DisplayName_L1="Role Officer - Review Roles" EntityType="AssignedSingleRole" Profile="RoleOfficerByCategory">
<Filter Binding="Role.Category.Id" Category="true" /> <Filter Binding="WorkflowState" Value="8" />
<Entry CanExecute="true" Permission="/Custom/ProvisioningPolicy/ReviewRoles/Directory_User" /></AccessControlRule><AccessControlRule Identifier="RoleOfficerByCategory_AssignedSingleRole_ReviewRoles_Directory_User_9" DisplayName_L1="Role Officer - Review Roles" EntityType="AssignedSingleRole" Profile="RoleOfficerByCategory">
<Filter Binding="Role.Category.Id" Category="true" /> <Filter Binding="WorkflowState" Value="9" />
<Entry CanExecute="true" Permission="/Custom/ProvisioningPolicy/ReviewRoles/Directory_User" /></AccessControlRule><AccessControlRule Identifier="RoleOfficerByCategory_AssignedSingleRole_ReviewRoles_Directory_User_11" DisplayName_L1="Role Officer - Review Roles" EntityType="AssignedSingleRole" Profile="RoleOfficerByCategory">
<Filter Binding="Role.Category.Id" Category="true" /> <Filter Binding="WorkflowState" Value="11" />
Technically speaking, the filter here says that the rule's permissions apply only on the assigned single roles:
- Whose
Id
of theCategory
of theSingleRole
is the same identifier as the value set for theCategory
property of the current user, in at least one of their assigned profiles, and - Whose
WorkflowState
is set to 8 or 9 or 11, which mean respectively pending approval 1/1, 1/2 and 1/3.
Properties
Binding required | Int64 | Binding of the property whose value is to be checked to restrict the application of the rule's permissions. NOTE: The binding must be based on the entity type defined in the access control rule. |
Category default value: false | Boolean | True to compare the value specified by the binding to the categories of the current user's assigned profiles. |
CompositeRole default value: false | Boolean | True to compare the value specified by the binding to the composite roles of the current user's assigned profiles. See the AssignedProfile topic for additional information. |
CurrentUser default value: false | Boolean | True to compare the value specified by the binding to the identifier of the account used by the current user to authenticate to Usercube. NOTE: The current user is the owner of the profile, allowed by the access control rule to perform an action and/or receive a notification. CurrentUser is tightly linked to the configuration of the SelectUserByIdentityQueryHandlerSetting . |
Dimension optional | Int64 | Identifier of the dimension whose value(s), from the user's assigned profiles, are to be compared to the value specified by the binding. See Dimension and AssignedProfile topics for additional information. |
Group optional | String | Group that the filter is part of. The access control rule filters the permissions by using the union (OR) of all filter groups, and the intersection (AND) of all filters within a group. NOTE: When not specified, the filter is part of the default group. |
Operator default value: 0 | AccessControlFilterOperator | Comparison operator. 0 - Equals. 1 - NotEquals. |
ResourceType default value: false | Boolean | True to compare the value specified by the binding to the resource types of the current user's assigned profiles. See the AssignedProfile topic for additional information. |
SingleRole default value: false | Boolean | True to compare the value specified by the binding to the single roles of the current user's assigned profiles. See the AssignedProfile topic for additional information. |
Value optional | String | Hard coded value to be compared to the value specified by the binding. |
