5.0.X to 5.1
1. Jobs
For any information about Jobs or Tasks:
a. Powershell
In the old configuration, the Tasks needed to have an InstanceIdentifier (-i) to be launched. This argument no longer exists today.
Old powershell:
& $exeSynchronizationJob -j AzureAD_Synchronization -i 'Synchronizing AzureAD' -s $sqlConnectionString -p $pathTempSynchronization -u $apiUri -a $jobSecret -c $jobClientId -t AzureAD
New powershell:
& $exeSynchronizationJob -j AzureAD_Synchronization -s $sqlConnectionString -p $pathTempSynchronization -u $apiUri -a $jobSecret -c $jobClientId -t AzureAD
Other change:
There are not openIdClient in all Synchronization. A new property is necessary to launch a synchronization with a command:
[Required]
"-o|--cacheFilePath ", "Specifies the cache file directory to reload provisioning cache." (SingleValue)
There are not OpenIdclient for manualProvisioning.
In FulfillLDAPTask, the property Port doesn't exist in 5.1. The Server property write with this rule : "Host:Port"
b. Configuration XML
In old configuration the task was named Job. All Jobs in 5.0.X are called Tasks in 5.1. The Executable "Usercube-Upgrade-ConfigurationVersion" writes correctly Job in Task and Use the scaffolding type. But the migrated tasks are not configured. it's necessary to check all Tasks and connectors too before importing configuration.
old Task configuration:
**<Job DisplayName_L1="HR - Synchronization" Identifier="HR_Synchronization" Connector="HR" OpenIdClient="Job" JobType="Synchronization"/>**
New Task configuration:
<SynchronizeTask Identifier="HR_Synchronization" DisplayName_L1="HR - Synchronization" DisplayName_L2="RH - Synchronisation" Connector="HR" OpenIdClient="Job" />
c. Api RunJob
This API no longer exists in version 5.1. To launch a Task on the server side you must use either:
  • The automaton (by creating a Job and linking the Tasks you want to launch)
  • The RunTask API
d. Information system appsettings
All the information of the information system is on this file: appsettings.ConnectionInformation.json. To launch Tasks that need to connect to this system and that are launched with the automaton, you must enter this information in this file.
f. Encryption appsettings.ConnectionInformation.json
All data from external systems is in a JSON that can be encrypted with an RSA key. Encrypt this with Usercube-Protect-X509JsonFile
