Usercube-Agent
This tool runs the Agent on a seperate server instance. The Agent is able to communicate with the Usercube-Server.
Examples
With a properly configured environment, the following command runs the agent. It listens on two different ports:
./identitymanager-Agent.exe --urls "http://localhost:6001;http://localhost:6002"
When the Agent starts, the following log should be displayed (if the log level is set to Information):
[xx:xx:xx INF] Now listening on: http://localhost:6001
[xx:xx:xx INF] Now listening on: http://localhost:6002
Arguments
Argument NameDetails
--urls requiredType String Description URL(s) that the agent is listening to.
