Usercube-Create-DatabaseViews
Generates entity model SQL views in the Usercube database. All views are prefixed by zz_. This tool deletes all views starting by zz_ and creates views from the entity model described in the running configuration.
For every EntityType, a matching SQL view is created from the UR_Resource table.
Example
The following example allows the user to connect to Usercube server at http://identitymanager.contoso.com, using the ClientId Job and Secret secret, to generate views for Usercube's database.
./identitymanager-Create-DatabaseViews.exe --api-secret secret --api-client-id Job --api-url "http://identitymanager.contoso.com" --log-level Debug
Arguments
Argument NameDetails
--progress-use-database optionalType String Description Update progress in the SQL database.
--progress-use-database-child-instance optionalType String Description Initiate child task instance.
--progress-use-api optionalType String Description Update progress with the API.
--api-client-id requiredType String Description Login used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-secret requiredType String Description Password used to authenticate to the server. Every request from agent to server needs to be authenticated with an OpenID Connect ClientId/Secret pair, linked to a profile with the relevant permissions.
--api-url requiredType String Description URL of Usercube server.
You can explore created views in the Usercube database's Views folder in SQL Server Management Studio
SSMS Views
Usercube-FillBankingDatabase
Example
Import the banking sources to the BankingSystem database.
The Banking demo application uses a database named BankingSystem. Once the database is created, the tables should be created and the sources should be imported, otherwise the Banking demo application will be empty.
Consider that the database's connection string is "data source=.;Database=BankingSystem;", the sources are located in the C:/SDK/DemoApps/Sources folder, and the BankingSystemTables script is located in C:/SDK/DemoApps/Banking. We initialize the database to create its tables, and import the sources.
--connection-string "data source=.;Database=BankingSystem;" --sources-path C:/SDK/DemoApps/Sources --banking-sql-path C:/SDK/DemoApps/Banking
Arguments
--banking-sql-path requiredType String Description Specifies the path to the folder containing the BankingSystemTables.sql file. Example Set path to C:/SDK/DemoApps/Banking: --connection-string "data source=.;Database=BankingSystem;".
--connection-string requiredType String Description Specifies the connection string of the BankingSystem database. Example Set the connection string's data source to the local machine: --connection-string "data source=.;Database=BankingSystem;".
--sources-path requiredType String Description Specifies the path to the banking sources folder. Example Set path to C:/SDK/DemoApps/Sources: --sources-path C:/SDK/DemoApps/Sources.
Usercube-Upgrade-DatabaseVersion
This tool is used to run the necessary migration scripts in order to upgrade the database structure from its current version to the most recent version.
Examples
To upgrade a database with the connection string databaseConnectionString, go to the Runtime folder of the newest version and launch the tool with the following argument:
./identitymanager-Upgrade-DatabaseVersion.exe --connection-string "databaseConnectionString"
If the database has been correctly upgraded, the following message should appear: Database has been upgraded to version X.X.X, with "X.X.X" being the newest version to which the migration was made.
With a Mode
The following example runs the database upgrade tool only for backward compatible changes.
./identitymanager-Upgrade-DatabaseVersion.exe --connection-string "databaseConnectionString" --mode BackwardCompatibleChanges
With the Execute Predefined
The following example runs the database upgrade tool only for backward compatible changes and the predefined script. As the predefined script is always executed in the other modes, this option is useful only when specifying --mode BackwardCompatibleChanges.
./identitymanager-Upgrade-DatabaseVersion.exe --connection-string "databaseConnectionString" --mode BackwardCompatibleChanges --execute-predefined
Arguments
--connection-string (-s) requiredType String Description Connection string to the database. Example --connection-string "data source=.;Database=Usercube;Integrated Security=SSPI;Min Pool Size=10;encrypt=false;"
--execute-predefined optionalType No Value Description Indicates that the predefined SQL file must be executed, when using the BackwardCompatibleChanges mode.
--mode default value: AllType Enum Description All - run all the script types. BackwardCompatibleChanges - only execute backward compatible scripts. Note: the previous runtime can still work. BreakingChanges - only execute breaking scripts. Note: the server must be stopped. CleanupChanges - only execute cleanup scripts, to cleanup the database after the server restarted with the new runtime. Example --mode BreakingChanges
--force-version optionalType String Description Forces the database version instead of using the current one to replay the migration scripts.
