Reconcile a Role
How to review non-conforming permissions, i.e. approve or decline the role suggestions made by Usercube after every synchronization. The aim is to handle the differences between the navigation values from the managed systems and those computed by Usercube according to the role catalog.
Non-conforming roles are considered as non-conforming assignments because no rule from Usercube's model can justify their actual assignment to an identity.
Role reconciliation with property reconciliation
For example, the AD hosts groups dedicated to various applications, and a role is assigned through group membership. An entitlement can be assigned to an identity by adding said identity's DN to the
memberproperty of the appropriate group. Usercube translates it by editing the identity'smemberOfproperty with the new group.
memberproperty.The result is a new item on the Role Reconciliation screen for said SAP role, plus an item on the Resource Reconciliation screen for the new
memberOfproperty for said identity.If the identity didn't have an AD account yet, then it is automatically created, and the item on the Resource Reconciliation screen displays also a modification of the
accountExpiresproperty.
reviewed too, its
workflow state
transitioned to
Manual(if approved) orCancellation(if declined, then a deprovisioning order is sent).
So let's say we add
C�dric Blancto the list of members of the SAP groupsSG_APP_SAP_1andSG_APP_SAP_211. Then, after the next synchronization, Usercube displays one item for each role on the Role Reconciliation screen, and one item for all changes in the AD account on the Resource Reconciliation screen:
This operation should be performed in cooperation with managers who know their team's expected entitlements.
| Input | Output |
| Provisioning (required) | Complying roles |
Review a Non-conforming Permission
Review a non-conforming permission by proceeding as follows:
Ensure that the
ComputeRoleModelTaskwas launched recently, through the complete job on the Job Execution page�� Or through the connector's overview page, Jobs > Compute Role Model.
On the home page, click on the entity type that you want to manage in the Role Reconciliation section, to get to the non-conforming permissions page.
Each non-conforming permission can be commented by clicking on the corresponding icon.
Choose one of the two possibilities to verify the permission:
Contrary to resources, reviewed roles are then displayed on the Role Review page accessible from the home page, and can be reviewed again.
- Either click on the approval icon to keep the non-conforming permission.
- Or click on the decline icon to delete the non-conforming permission.
Use bulk provisioning
Several roles can be reconciled simultaneously by clicking on Bulk Reconcile Roles.
Verify Role Reconciliation
In order to verify the process, check that the changes you ordered appear on the corresponding user's View Permissions tab.
