Create a Role Manually
How to create single roles manually.
A single role is a way to represent an entitlement that is to be assigned to an identity. It brings a layer of abstraction through a user-friendly name, close to the business view.
To be effective, roles must be linked to actual entitlements in the managed systems. Within Usercube, an entitlement assigned to an identity is in fact represented by the value of a given navigation property, in a resource owned by said identity. Thus, each role is linked to one navigation rule per entitlement.
For example, imagine that we want to grant unlimited Internet access to the administrator profile of an identity. This entitlement won't be assigned directly to the identity but to its AD administration account. In our Active Directory, there is a resource called
DL-INTERNET-Restrictedidentified from among AD entries as a group. So we need to add this group membership to the properties of the identity's AD account, usingDL-INTERNET-Restrictedas a value of thememberOfproperty.
| Input | Output |
| Classification (required) | Single roles |
Create a Single Role
Create a single role by proceeding as follows:
On the home page in the Configuration section, click on Access Roles to access the roles page.
On the roles page, click on the adequate category and create a role by clicking on + New at the top right corner.
Fill in the fields.
Identifier: must be unique among roles and without any whitespace. -
Name: will be displayed in the UI to identify the created single role. -
Tags: label(s) that can later be used to filter the target roles of access certification campaigns.NETWRIX recommends using role tags when you want to perform an access certification on a set of roles that are from several categories.
Category: category which is to contain the created role. -
Secondary Categories: other potential categories which are to contain the created role. -
Approval Workflow: represents the number of validations required to assign the created role. -
Approve Role Implicitly: needs at least simple approval workflow.Implicitmode bypasses the approval step(s) if the person who makes the role request is also the role officer.Explicitrefuses said bypass.Inheritedfollows the policy decision to approve roles implicitly or not. -
Allow Manual Assignment: allows the role to be requested manually.Set to
No, the role can be assigned only via automatic rules. Therefore, the associated single role rules cannot have theirTypeset toSuggested. -
Hide in Simplified View: hides the role from the users' Simplified View in View Permissions dialog. This setting does not apply to roles which are either inferred or have workflow states which require manual action. -
Maximum Duration: duration (in minutes) after which the role will be automatically revoked, if no earlier end date is specified.The maximum duration impacts only the roles which are manually assigned after the maximum duration is set. Pre-assigned roles are not impacted.
- If no duration is set on the role, the maximum duration of the associated policy is applied.
- If the duration is set to 0 on the role, it prevents the associated policy from applying its maximum duration to it.
Grace Period: duration (in minutes) for which a lost automatic single role is prolonged. A review will be required to validate or decline the entitlement prolongation. Inferred entitlements won't be lost unless the end of the grace period is reached or the prolongation is declined.The grace period is only applied if the loss of the entitlement is due to a change in the rules, i.e. rule deletion or criteria changes.
If the grace period is not defined, the value is inherited from the policy.
Click on Create and see a line added on the roles page.
Create at least one navigation rule with the single role as a criterion.
Create a Navigation Rule
Navigation rules aim to assign given resources to identities based on specific criteria. A navigation rule sets the value of the navigation property on a specific resource, if a given condition is met. It is linked to a parent resource type that sets the target entity type. One rule creates one navigation.
Create a navigation rule by proceeding as follows:
On the home page in the Configuration section, click on Access Rules to access the rules page.
In the dropdown menu at the top left, choose the entity type to which the future navigation rule will be applied.
Click on the Navigations tab and on the addition button at the top right corner.
Fill in the fields.
Join: target property whose value is impacted by the created rule.Resource: value to be set on the JOIN.Navigation denied: option that forbids the resource assignment.Offset of effective date: time period that defines the actual effective date according to the value's start and/or end date. An offset of effective date can be useful for some attributes. For example, account activation and deactivation can be managed according to the start and/or end dates.- Criteria: conditions that, if met, trigger the created navigation.
Click on Create and see a line added on the rules page.
Impact of Modifications
When deleting a single role, caution must be used when deleting the corresponding navigation rules. Indeed, these rules thus lose their criteria and may be applied to far too many people after that.
Verify Single Role Creation
In order to verify the process, check that the role and rule are created with the right parameters.
For roles, click on Access Roles on the home page in the Configuration section.
Select single roles and find the role you created inside the right category and with the right parameters.
Our example would look like:
For rules, click on Access Rules on the home page in the Configuration section.
Select navigation rules and find the rule(s) you created with the right parameters.
